To replace the front brakes rotor at 2015 Prius c do I need a special tool??
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by CARSFAN4, Sep 26, 2023.
  1. CARSFAN4
    CARSFAN4 Junior Member
    23
    Los Angeles
    2015 Prius c
    My front left brakes make noise and lack breaking force. I assume this must be the used pads and the rotor which makes noise due to non uniform surface. Do I need to use a special tool to dismantle the brakes rotor?? I know I need a special tool for the brake caliper to push back the piston when I replace the pads. How about the rotor?? Thanks
  2. ChapmanF
    15,614
    If it's like the liftback and the previous generations, no, the rotor will just come right off. (If it's stuck, you can borrow an M8-1.25 bolt from anywhere and use it in the threaded holes, to pop it loose.)
    You also won't need any very special tool to push the caliper pistons back. The fancy tool is needed for the Gen 3 liftback rear calipers, because those are combined with the parking brake.
    CARSFAN4 likes this.
  3. CARSFAN4
    23
    Los Angeles
    2015 Prius c
    Thank you, I am going now to the Autozone to find out.
  4. douglasjre
    douglasjre Senior Member
    1,877
    653
    Orlando, FL
    Where do I begin
  5. Tombukt2
    Tombukt2 Senior Member
    9,131
    1,585
    Durham NC
    Large 16-in channel locks squeeze this type of caliper down with one hand some people call them slip joint pliers You don't need the special tool that fits on your ratchet to turn the caliper down as it's not that type The rotor you can just dink it off with a hammer just lightly touching the very edge bink.it falls off after the two 17 that hold caliper bracket on the car. So after the 17s and the caliper bracket and the caliper slide off or tap off with your hammer slide right off the rotor then you tap your rotor or pull on it and it falls on the floor You don't waste time resurfacing these rotors it'll cost you more to resurface than it will to buy one generally speaking remember labor is costly in the States parts are generally cheap so if you have to pay somebody to run a brake lathe It's costing more than the brake part you're usually turning unless it's a one-off or something like that which you won't see a lot on the Prius chat.
  6. CARSFAN4
    23
    Los Angeles
    2015 Prius c
    I went to Autozone and despite the fact the salesperson didn't know I made a search on Google and found these $4 M8-1.25 Hex. Flange bolts 30mm length. I will buy them but can u confirm these r the right ones and I would appreciate if u can send me instructions or a link on how to. Thanks
  7. Tombukt2
    9,131
    1,585
    Durham NC
    Just smack on the road or a few times with a hammer with the brass drift or something like that and usually the rotor will just fall off If it's really stubborn and you're in the New England states are in a rust belt some kroil or something similar in between the holes where you would normally screw in the bolts to force the thing off just shoot some penetrating lubricant in those holes again smack that high hat part of the rotor with a ball peen or dead blow hammer and in a few minutes without destroying anything it will just fall off the car.
  8. douglasjre
    1,877
    653
    Orlando, FL
    If u like your life you won't buy Chinese brakes from the three auto parts stores or the two online retailers of Chinese made crapola
    This Chinese junk needs to be outlawed for public safety
  9. douglasjre
    1,877
    653
    Orlando, FL
    Stress is axial. Strain is shear direction. Do u know what grade your application calls for?
    If you don't know all this I think you'd better get the bolts from the dealer. Pads too
    #9 douglasjre, Sep 27, 2023
  10. douglasjre
    1,877
    653
    Orlando, FL
  11. douglasjre
    1,877
    653
    Orlando, FL
    Chinese part failures in my life that are most memorable:
    1 brake fluid reservoir broke 2h into service dumping its contents on motorcycle and driver resulting in no brakes nearly killing rider and passenger
    2 Chinese Li battery fire at warehouse burned it down in early August
    3 Chinese head gasket failed after 10k miles. 16h job in the shitter
    4 new Chinese rotors have soft spots. Do over
    5 Chinese alternator lasted 1 year
    6 Chinese shocks lasted 10k miles and sucked for the last 5k
    7 Chinese drywall
    8 Chinese imitation water pump says Denso but lasted 5k miles and bought on Amazon. Job eaten
    9 Chinese imposter ngk plugs failed after 30k miles. Not iridium clearly
    PRC is an oppressive govt. The people aren't the problem their govt is
  12. Mendel Leisk
    38,726
    He’s shopping M8x1.25 bolts just to break loose the rotors.
    Due to this:
    Then this:
  13. Tombukt2
    9,131
    1,585
    Durham NC
    On a car in Western Massachusetts I stripped those two bolt holes trying to screw up the two bolts in to force the road or off usually now in a heavy rust state what I do is I use those two bolt holes to put a light little bit of pressure on the road or face so I can take my spray hose of my Aerokroil orange can get a shot in each hole so the coil can get in between the back of the hat of the rotor and the face of the hub bearing and I just rock that back and forth or tap gently around the hat where the lugs are coming through and that croil gets in between the two pieces a little more tap tap tapping at a tiny bit more pressure to the bolts just a little quarter turn or something tap tap tap dink and let's go.
  14. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    How do you think you know that the left front "lacks braking force" ??
    You should NOT blindly replace rotors until an inspection confirms that
    they have a problem and need to be replaced.
  15. Tombukt2
    9,131
    1,585
    Durham NC
    Let me tell you I very often have mismatched brakes on my own Gen 2 Prii. It's actually very common for me to have a bad wheel bearing and for me to grab another hub off of another vehicle temporarily so I don't have to stop driving and listening to that awful racket so on and so forth and I've never had a problem sometimes I've actually forgot that my brakes don't match and I wind up running them until they actually need to be replaced and don't even know it till I'm taking it apart and I realize whatever I realized that geez 40,000 mi ago or whatever it is but I would never not with the same breaking force and whatever I would think that would be in my breaking system something not squeezing that caliper down for whatever reason it's receiving some signal from the tone ring or whatever the heck. I wouldn't think it would be because of a brake pad to rotor problem unless that's very evident with your eye or there's air in the line I generally not seen that before unless I've changed and actuator or something along those lines doing a brake job doesn't do it unless you just don't know what you're doing I guess.
  16. Tombukt2
    9,131
    1,585
    Durham NC
    And I'm truly sorry all you folks are having problems with car parts I guess I've been really lucky I don't seek out Chinese fake parts per se maybe for - plastics and things like that but generally for other things I try to use maybe anywhere but China China other Asian countries Vietnam whatever I guess I've just been really lucky the wheel bearings and things that I have bought I'll just chalk it up to look and leave it at that I guess I certainly haven't been paying $249 per wheel bearing more like 50 and I have had no problems and we keep our cars our cars aren't flipped tripped messed with none of that nonsense they stay right here I see them everyday. Nothing I buy is for resale ever I use it up then it sits here for a while while I strip it and do whatever and then it goes to salvage there is no second chance none of that nonsense so I know what goes on with my stuff here and that's all I'm accountable for.
  17. ChapmanF
    15,614
    Any M8-1.25 bolt more than, say, 5 mm long will do the trick, if the rotor doesn't just flop right off when you remove the caliper and pads.
    The car is put together with, like, a gazillion M8-1.25 bolts. You can always look for one nearby, say holding the air filter box on or something, and borrow it, and put it back.
  18. Mendel Leisk
    38,726
    I think you need close to an inch, to get through the rotor thickness.
    ^ I concur. Hopefully OP will do some research before plunging in. It’d help if the Toyota Repair manual had an explicit “brake inspection” section; instead the inspection practices are lumped into a complete tear down.
    There’s a decent chance his rotors are just fine. He’s yet to disclose anything specific, say brake pad thickness, which can be determined just with the wheel removed.
    Anyway, some repair manual info attached. < Ugh, just realized OP has Prius c, attached is gen 3 Prius. Still might be of interest, but don't count on it. For Prius c Repair Manual info, maybe take out a short Tech Info subscription?
    #19 Mendel Leisk, Sep 28, 2023
  19. ChapmanF
    15,614
    I don't think they're that thick up in the hat part where those threaded holes are.
