To solenoid or not to solenoid?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by h1ph0panonymous, Oct 10, 2023.
  1. h1ph0panonymous
    h1ph0panonymous Junior Member
    67
    Okay long time lurker (2 weeks lol) first time poster.
    after reading numerous posts here about the Red Bullet and Quantum Power solenoids for the oil valve timing (VVT) I’m left more confused than certain.
    first question, Wth is the track version of these and why isn’t that the default version for their websites? Makes it more sketchy.
    second question, it gives you more torque is what the consensus agrees here so wouldn’t this thing reduce engine lugging in eco mode on lift offs and up hills/slopes and get you up to the most gas efficient speed the faster you are able to accelerate to that most gas efficient speed thus giving you better gas mileage?
    2014 Pruis Four
    more stupid questions to come just keeping them on topic one at a time.
    Burna J likes this.
  2. KamiKKazi
    KamiKKazi Member
    89
    58
    OC
    The track edition is awesome. If you drive fast this may give you better gas mileage, it did for me. Get the track edition it’s worth every penny. Also get a throttle controller. I got the 9-drive throttle controller on amazon it’s cheap but works.
  3. ETC(SS)
    6,540
    I'm a little confused as to why Toyota - who SELLS cars based on gas efficiency, doesn't use them.
    HOW exactly to they make the car more efficient?
    I'm nearing retirement, and I figure that if I can get Toyota USA to use these and pay us 1/1,000,000th of the money that they would gain from using Red Bullet and Quantum Power solenoids, I wouldn't have to fix phones for a living!!!
    Just imagine!
    The G5 Priuses have an EPA-estimated 57 miles per gallon combined fuel economy.
    They use same basic powertrain as the G3's and G4's - hopefully without the horrible engineering defect in the G3 that makes them suffer from the death rattle at 150,000 miles.
    Most people have 10 fingers, and so they think in base-10.
    If we could improve the G5s by just 3 little MPGs by adding just a few hundred dollars(?) worth of this undiscovered technology then that would be SOLID GOLD for Toyota-USA's marketing team!
    60-MPG by US EPA metrics instead of 57!!!
    We could even sell it to domestic car makers suffering under the oppressive yoke of our CAFE regulations.
    I'm telling you.
    It's a billion dollar secret!!!!
    foaktree, Mr. F and Mendel Leisk like this.
  4. ChapmanF
    15,435
    Or it was, till you went and blew it wide open. Nice going.
  5. AzusaPrius
    AzusaPrius Senior Member
    1,827
    811
    I have the track version of the Red Bullet.
    I can not see a drop in mpg as I have other things that improve mpg installed.
    So I am enjoying the quickness it provides.
    Right now I am getting 50-65 mpg.
    So I would have to say to solenoid is the answer to the question.
    Make it a Red Bullet solenoid and use promo code "azusa" to save some cash.
  6. V Sport Wagon
    V Sport Wagon Member
    227
    83
    It's all in how you drive it, the more power adders you put on, the more you're in the throttle burning more gas, more RPM...if you have self control and use these just to get to speed while pulse and gliding, you should see the best results. Driving faster or harder never ever nets better MPG, don't believe the lies.
    Burna J and ASRDogman like this.
  7. fuzzy1
    10,149
    In 14 years of driving a G3, mostly in ECO, I can't remember it doing any 'engine lugging', ever. Lugging is what our stick shift cars do when the spouse, or sometimes I, pick a too-high gear.
    According to several old threads here, the most gas efficient speed in a Gen3 Prius is about 15 mph according to one domestic source, somewhere between 10-20 mph according to a group of Japanese hypermilers. As speed rises above that, MPG goes monotonically downhill. Bob Wilson measured out and posted an excellent MPG vs MPH chart, unfortunately the essential graph image was lost to one of many website host migrations since.
    h1ph0panonymous likes this.
  8. h1ph0panonymous
    67
    How did you get the track version from red bullet, I looked and don’t see it, gotta ask personally on their email?
    I see thank you, Prius is new to me, 3 weeks new after driving a Ford Fusion SE 2017 for 6 years there’s a certain hill with a certain speed limit that cars transmission didn’t like and would engine lug a lot only way I knew was the deep bass of the engine on those hills so I would either have to go 5 under or 5 over depending on flow of traffic or no traffic at all just seeing if that’s an issue with the planetary Toyota CVT transmission.
    that most gas efficient speed is insane.
    side note got a P0607 CEL pop up that my scangauge showed and only that code, cleared it and went away hasn’t came back, I only have had a drop in K&N filter put in it 2 weeks ago but that’s been like 1k miles ago so hoping the code stays away as it rare I read.
    2014 Prius Four just hit 40k miles
    #8 h1ph0panonymous, Oct 13, 2023
  9. fuzzy1
    10,149
    The eCVT is a power split device, not merely a "transmission".
    The normal way that the Toyota HSD system works is that the engine management system spins up the ICE RPM to deliver whatever power you request, then the eCVT is managed to operate at whatever 'effective gear ratio' is needed to match th engine speed to the wheel speed. The eCVT should not be holding down the ICE RPM in a similar way that a poor gear choice in a traditional car causes lugging by holding engine RPM and power too low.
    As for the deep bass of the engine, note that the Prius engine is nearly always managed to operate on a specific high-torque load line on its BSFC (brake specific fuel consumption) chart, even in gentler flat road less-noisy conditions. That line runs right through the middle of the engine's most efficient operating conditions.
    That is a reflection of the fact that in normal use, much of the friction losses are to air drag, which keep dropping rapidly as speed drops. Other mechanical frictions also fall at lower speeds, though not as dramatically.
    In theory, MPG could continue rising as speed drops even further, down to walking speed or slower. But in practice, this is limited by the electrical housekeeping power of the many engine and braking and other system controllers and human interfaces and displays in the vehicle. In the Prius, these fixed loads run somewhere in the vicinity of 400 watts. At lower speeds, this energy is amortized over less distance, reducing MPG. From several analyses from different groups, the Prius's balance point between fixed- and variable-speed power losses seems to be approximately 15 mph, thus the highest MPG happens at the about this point. In the future when these electrical controls can do all their jobs with less electrical power, this highest-MPG-speed may shift to even lower speeds.
    Prius low speed fuel efficiency is so good that, when making speed vs cost tradeoffs, your equations must include the value of your time. There is usually no sense going ever slower to save fuel cost, when the resulting fuels savings is less than the increased loss of the value of your time.
  10. h1ph0panonymous
    67
    Thank you for the schooling lol but I was refer to my previous car was making that deep bass engine lugging sound up hills when in a higher gear, so far haven’t had that issue with my Prius going up the same hill.
    But yeah I always calculate time into my most gas efficient speed knowledge so I assume the faster you can get to the last gear on the car with the lowest RPM after that then that would be an MPG “gain” thus the torque from the aftermarket solenoid would give this effect in theory?
    V Sport Wagon likes this.
  11. V Sport Wagon
    227
    83
    Yes get to desired speed quicker and then stay in the inertia at desired speed will net good MPG . The best tool would be a throttle commander like ShiftPower 4.0+ though since it’s power can be adjusted on the fly rather than a Solenoid that’s more or less one power setting and requires tools to remove.
  12. ChapmanF
    15,435
    I see that's another one of this kind of thing, plugged between your pedal and the ECU pedal input. Changes what the ECU sees for the pedal position.
