Today hot weather = increased mpg. Why?
Discussion in 'Generation 1 Prius Discussion' started by srponies, Jun 7, 2011.
  1. srponies
    srponies New Member
    WI
    2001 Prius
    My '01 Prius is parked outside. Hasn't moved since Sunday. Today was a HOT day (99deg). I went for a drive and had very different mpg, up approx 2mpg by the time I had driven less than an hour around town. Power level felt increased, battery seemed to be used more frequently. The "Current" MPG, which is typically 25-50, was now much more frequently 50-75, and even seemed to be at 100 mpg much more frequently than when I take the same route. The Battery only mode occurred more, too.
    Is this a good thing, or maybe indicative of a problem? (Like a light bulb getting bright before it burns out...)
    Thanks,
    Steve
    49,380
    probably because the engine is always at operating temp and doesn't have to warm up much.
  3. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    It's a great thing, the car gets to full hybrid mode more quickly with the engine heating up more quickly, and it really takes advantage of everything it's got. I had to stop in somewhere for a half hour today, when I left I was in full hybrid mode (stage 4) by the time I left the parking lot :)
  4. StevL
    StevL Junior Member
    22
    South Carolina
    Also in hot weather the gasoline engine will run more lean, not as much fuel is used.
    Steve
  5. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    And warm air is less dense (especially warm moist air), so driving through it is easier.
  6. pictone
    pictone Junior Member
    Atlanta
    Very strange. When I first received my 2011 Prius III in April, I was consistently getting 45-47 mpg doing local driving (north Atlanta suburbs are very hilly). Now that it's gotten much warmer (consistently in he 90's) I am getting only 37-40 mpg doing the same driving.
  7. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    In your case, I have to ask if you are running the air conditioner. I know it is not only hot but also humid in Atlanta so I would suspect that you're running the A/C to cut the heat and humidity.
    IF this is the case, it's important to keep in mind that the A/C is electric and pulls from the hybrid battery. So if you are driving along and in "full electric" mode much sooner and more often, you will discharge the battery more quickly. Add to that the A/C and you discharge the battery even faster. So the gas engine has to kick in more often to recharge the battery. While this is happening, you are achieving a considerably lower instantaneous MPG. You might also find yourself idling with the engine running more.
    I might be off base, but I also might be dead on.
  8. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Also tires roll easier.. higher pressure and less flex loss
  9. pictone
    Atlanta
    Tony, you have a good point. Although I've always used the AC since I purchased the car, it is definitely working much harder in the heat. Although I've never seen the battery display drop below two bars, the engine probably kicks on more often, especially when sitting at these infamous Atlanta long traffic lights. Thanks.
  10. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Use the ECO button and turn up the temperature. I found out that I could barely tell the difference between 75-77 degrees because just removing some of the humidity is all that matters.
  11. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    With all 3 generations of Prius, I've observed increased MPG from higher humidity. That includes moister air during the winter too, not just summer. It helps with the outcome of combustion, contributing to a bit more oomph than usual with the same amount of fuel due to the water expansion.
  12. pictone
    Atlanta
    I tried using ECO for a few weeks when I first got the car. I don't care for it. I like more responsiveness when pressing the accelerator. ECO feels like a stepping on a sea sponge.
  13. cyclopathic
    3,292
    547
    2014 Prius c
    Not after you put in K&N filter :))
  14. briank
    briank Solar Powered
    51
    Massachusetts
    I agree, so I usually keep it in normal mode and when I'm going to be at cruising speed for a while (highway driving), I'll enable ECO mode, primarily to lower the A/C power usage.
  15. pictone
    Atlanta
    I decided not to try the K&N route, as the vast majority of posts on this forum seem to say that it provides little or no additional benefit with the Prius.
  16. fuzzy1
    10,159
    How does it get more lean? Shouldn't the emission control system keep it fixed to the standard 14.7 ratio?
    In a standard Otto cycle engine, the hotter intake air will have lower density, which leads to less intake vacuum / less pumping loss / less air mass consumed, therefore less fuel mass also. But this should happen without leaning out the ratio.
  17. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    If a WB sensor is used, as is supposedly the case in the 1st gen Insight, bursts at an A/F of 22 can be possible before the CATs require an A/F of <14.7 to prevent induced imolation.
    From postings it seems as if the GenII Pri uses a WB type. Time to break out the WB Innovate System and run some tests.
  18. critterz
    critterz New Member
    2001 Prius
    Not true, hot weather richens the full mixture. Hot air is less dense which slightly changes the fuel ratio. That's why racecars always run slower in the heat. On a Prius it's the other stated reasons.
  19. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    Remember the hot air intake for winter?
  20. critterz
    critterz New Member
    2001 Prius
    That's to prevent carburetor (and some injection systems) icing.
