Today my car shut itself off while at a stoplight and would not restart for about 5 min. Any ideas?
Discussion in 'Gen 3 Prius Main Forum' started by SdotC, Sep 12, 2018.
  1. SdotC
    SdotC New Member
    American Canyon, Ca.
    So on my way home from work today i came to a redlight. As my car came to a complete stop it just shut itself off completely. I attempted to restart it right away but it wouldnt even turn on the battery. Finally after 5-10 mins of sitting in the middle of traffic with my hazards on the car decided to turn on. When it turned off no lights or anything came on and no beeps or sounds were made. Has anyone experienced this or anything similar?
    49,444
    welcome!
    maybe a bad inverter pump, how many miles on her?
    have you owned her since new?
    amos likes this.
  3. JC91006
    16,480
    8,397
    What year is your car? Do you have enough fuel in it?
    amos likes this.
  4. SdotC
    SdotC New Member
    2015. Yeah i had half a tank in it. No lights came on before or after it happened and it didnt make any sound or beeps out of the ordinary either.
  5. SdotC
    SdotC New Member
    Thanks. Ive looked stuff up on the page previously but just now created a profile. Yes im the original owner. I currently have just under 125k on it. Its last service was month and a half ago at toyota.
  6. bisco
    49,444
    very odd, maybe a loose connection? but that doesn't make any sense either.
  7. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Double check both battery connections; tight, not loose, orange lever wasn't accidentally bumped when accessing spare tire region.
  8. bisco
    49,444
    i wonder if the inverter could have overheated
  9. iskoos
    iskoos Active Member
    401
    246
    Orlando, FL
    I was gonna ask how old the aux battery was but realized your car is just 3 years old.
    My (2010 Gen3) refused to start a few months ago with no warning or any symptoms. And it turned out to be a bad aux battery. It was the original (8 years old). Replaced the battery and all was okay.
    Mine did not shut down during the traffic but it refused to start after a quick stop. Nothing was happening as you mentioned. I couldn't even turn the electronics on. Then after sitting a few minutes, it powered on and engine started.
    3-year-old battery is too new to do this but maybe there is a problem in the charging circuit and 12v battery ran down. It should be easy to check.
  10. amos
    amos Active Member
    341
    281
    los angeles
    Im just reading bout a new recall of 2.5 milion prius and auris made between 2010 to 2014 It says hybrid software update needed. Says that instead of moving to a safe position as needed . it may just shut off totally in extreme cases causing a complete shut off of all systems and engine too.
    Raytheeagle likes this.
  11. egn83b
    egn83b Junior Member
    59
    Rarford nc
    There has to be some kind of motive with toyota coming out with a software update again for the prius. The inverter issue must be still pluaging toyota in some way in court so they are covering there rears in case of an accident. I always get the feeling these updates are designed to phase these cars off the road by some kind of phased obsoletes beyound normal wear and tear. If toyota had issues with the third generation why didnt they offer an upgraded inverter or buy back for the next generation. Just my 2 cents.
  12. bisco
    49,444
    wow, the beat goes on...
  13. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    Strange but 12v would place to start. Recently I replaced on older 12v that stranded me, but when I went back for it the car started. Your 12v is young shoudl be good unless sometime it discharged.
  14. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Long as deaths are not reported due to inverter failure and the continue to avoid loss of return of investment, they feel entitled not to resolve the issues with the settlement you suggested. If no one is willing to come forward and slap them with a lawsuit then the best we can do as consumers is to not buy their products. Honda Civic Hybrids here I come.
  15. egn83b
    59
    Rarford nc
    The problem is toyota knows they have issues with there product because why so many updates. They are in litigation for it right now. I have a honda hybrid ima product it sucks. Toyota has the best hybrids on the road currently. Most of the other brands have issues with battery managment and control issues with braking and acceleration. The problem honda faced with the ima is that the battery never had a chance to recharge when it went low the ecu blocked charging. Now honda revised to a new system which to my knowledge work on the same tech as the prius.
