Too much road noise?
Discussion in 'Gen 4 Prius Main Forum' started by priusmouse, Nov 24, 2022.
  1. priusmouse
    priusmouse Member
    251
    84
    Long Island, NY
    2023 Prius
    My prius used to insulate me really well from the noise of the wheels on the road at high speeds etc. but lately after more than 150k miles it is not as quiet a ride as it used to be.
    Is there anything affordable that can be done to restore the quiet-ness it had during its earlier days?
    49,694
    some people apply dynamat. are you sure it's not your tires?
    kc5dlo and FuelMiser like this.
  3. priusmouse
    priusmouse Member
    251
    84
    Long Island, NY
    2023 Prius
    I did have a flat recently. Could the pressure be too low?
  4. -Yousef-
    -Yousef- Junior Member
    24
    Saudi Arabia
    Most likely reason for increased cabin noise overtime is tires as they do get louder as they age . Check the pressure first and if not, likely you'll have a quieter ride whenever you'll have them replaced.
    Mambo Dave likes this.
  5. prius16
    prius16 Active Member
    462
    243
    New England
    2022 Prius Prime
    What tires are you using?
    How many miles?
    Do you rotate the tires?
    Code:
    https://www.youtube.com/watch?v=8m-o3PbJ9Pw
    Is Your Car Too Loud? Start With These Simple Steps To Find Out Why
    The Car Care Nut
    Nov 23, 2022
  6. FuelMiser
    FuelMiser Senior Member
    1,303
    890
    Monument, CO
    This. Worn tires create a lot of road noise. Apparently, ample tread muffles the noise.
    douglasjre and Mambo Dave like this.
  7. Leadfoot J. McCoalroller
    7,237
    6,784
    Pennsylvania
    2018 Prius c
    Don't forget wheel bearings. They're silent when new and sound like WWII bombers once aged, and it changes so slowly everyone forgets.
    They aren't cheap to change, but that's where the real quiet is.
    ..okay the fronts aren't cheap to change, and you only need one loud one to make the whole car sound awful.
  8. twc
    twc Junior Member
    MI
    Howdy, I was told that's my problem, driver-side front bearing. Did you have yours changed at a dealership or another shop, and cost please? Thanks, Tim
    douglasjre likes this.
  9. Leadfoot J. McCoalroller
    7,237
    6,784
    Pennsylvania
    2018 Prius c
    Our Prius is (slightly) too young to have suffered any wheel bearing failures. I have had bearing failures and replacement experiences with other cars.
    The Prius uses exactly the same type of bearings as most other medium-sized Asian cars. Bog-standard parts same as any Accord, Outback, Altima or Corolla. For this reason I suggest using an ordinary neighborhood mechanic. They should be able to save you a lot vs. the dealer. Again relating our pre-Prius cars- I've paid $200 to have a rear bearing replaced and about $400 for a front as they involve more work.
    The most important thing to work out in a bearing replacement is correctly identifying which of the four are making all of the howling noise.
    These things tend to be ventriloquists. There is a specific tool known as "Chassis Ears" which has an excellent track record for helping mechanics correctly spot which bearing to replace. I would ask to make certain your shop had one and used it for your diagnosis- nothing worse than the fingerpointing after replacing the wrong one.
    Good luck!
    twc likes this.
  10. twc
    twc Junior Member
    MI
    Thank you very much. I had a shop look at it and he said he thought it was the one I mentioned, but the shop wouldn't do it due to the regenerative braking aspect of the wheel. Thanks for the tip on the "chassis ears." I hope to find another shop I can trust to do it. I'm new to the local area. God bless you all.
  11. bisco
    49,694
    there is no regenerative braking in the wheel, that takes place inside the tranny
    twc likes this.
  12. Robert William Aston
    26
    new zealand
    see a really good video on this ...search at The Car Care Nut - YouTube
  13. rjparker
    rjparker Tu Humilde Sirviente
    8,102
    4,805
    Texas Hill Country
    Probably $300 is the low end with cheap wheel bearings (hubs) that may go out in a year. Good oem or Timkens can easily last 8-12 years but may be $500 each installed. The bearings are the same as a gas only car, only a uneducated shop would think regen made them different. They will have an abs sensor built in like any modern car. A hybrid simply makes more use of that wheel speed data.
  14. douglasjre
    douglasjre Senior Member
    1,901
    661
    Orlando, FL
  15. douglasjre
    1,901
    661
    Orlando, FL
    One of my Prius are in New York City right now. $300 cash, a five-star review, And I taught him how to replace the hybrid packs for people
