took out my left headlight, prius won't boot
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by donbright, Aug 12, 2020.
  1. donbright
    donbright Active Member
    241
    150
    33
    oklahoma
    Hello,
    Any help is appreciated. Car had sat for a day or three. I took out my left headlight in prep for changing the inverter coolant pump (added note @JC91006: 197,000 mile preventative maintenance).
    I popped off the front bumper, and loosened the side bumper, took the headlight assembly out, unplugged it.
    Now the car will not boot.
    FOB can unlock/lock, hazards work, I can hear the brake pump when i hit the brake pedal, the headlights work, brights work, but nothing else. (a bit fuzzy on the proximity thing... can test more) No lights at all except flashing SKS or "door is ajar".
    the rear hatch switch works to open it. however the little black button on the door does not work to lock, not on the hatch nor the driver door.
    This was a FOB that never worked inside the dash, only worked wireless thru sks.
    12V battery is 12.40 measured from the under hood points and from the rear well.
    12v extras: i left my bluetooth obdii reader plugged in, which i have done before. left my dashcam plugged into 12v cigarette lighter, which i have done before (should not draw power in theory).
    Disconnected battery for several minutes, reconnected, no change.
    Used a jump brick on the underhood points (fuse box, nearby bolt), no effect.
    note added jc91006: AM2 fuse is tested 0 0hms with a multimeter
    Thanks.
    #1 donbright, Aug 12, 2020
  2. JC91006
    16,482
    8,399
    If I had to guess, you probably broke it by pressing buttons more than 100 times during that short video.
    Did you check the AM2 fuse in the engine fuse compartment? You didn't explain why you are changing that pump
  3. donbright
    241
    150
    33
    oklahoma
    thanks. AM2 is tested good on multimeter. replacement is b/c coolant and inverter has never been listed as replaced with 197,000 miles of carfax. ha ha didnt realize how fast i was pushing power, i do have an extra power button somewhere i think.
  4. JC91006
    16,482
    8,399
    there is a "SKS" button by your knee area when seated, did you press that button by mistake?
  5. donbright
    241
    150
    33
    oklahoma
  6. JC91006
    16,482
    8,399
    So I was right on my first comment, "you broke the car by pressing too many buttons"
  7. donbright
    241
    150
    33
    oklahoma
    bwaha well part of my job is data entry so i guess its a habit... back in the day we used to get graded on keypresses per hour
    JC91006 likes this.
