Tools for diagnosing Generation 2 ?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by John Casteel, Mar 9, 2017.
  1. John Casteel
    John Casteel Junior Member
    22
    Savannah, ga
    The car has been so reliable that I seldom come on PriusChat but...
    Driving my 2007 with 110,000 miles on Tuesday I got the following lights:
    Master warning light
    check engine light
    Hybrid system warning light
    amber Brake system warning light
    Maint Reqd
    on restart I have the following lights:
    check engine light
    Maint Reqd
    I checked my log book and I am just now due for an oil change. This probably takes care of the Maint Reqd light.
    I am going to stop by AutoZone in the morning and let them pull codes.
    Question #1: I don't mind buying some diagnostic tools if they will help me. What should I consider? Assuming that the error code indicates replacing the traction battery then will, for instance, a ScanGuage II help me diagnose which battery modules need replacing? I do not have a Windows computer. I run Linux. I do have a multimeter.
    Quesiton #2: I am assuming the worst. Maybe it is something else but I have time to do some research before I get my codes. I am looking for the definitive thread or youtube video on replacing modules in the traction battery. I've found lots of bits and pieces but if someone could point me in the right direction I'd appreciate it. In particular I'd need to know how to actually diagnose which modules and then post replacement do I need to rebalance (or whatever) the entire battery pack.
    I have a second car so I'm not dead in the water. Unfortunately timing is poor as I work 7 of the next 8 nights and then I take off on a short vacation with my 12 year old, but this will all work out.
    I'm in Savannah, GA and an initial search only finds one garage that seems to be hybrid specific. I'm a long time DIY guy and cheap besides so I'd prefer to fix on my own.
    Thanks in advance.
  2. John Casteel
    22
    Savannah, ga
  3. AzWxGuy
    AzWxGuy Weather Guy
    982
    496
    Tucson, AZ
    2021 Prius
    Don't let Autozone clear the error codes. Read them, yes. But don't clear them in case you end up going to Toyota service for a proper and $$ diagnostic. My first guess would be to check the 12V battery.
  4. John Casteel
    22
    Savannah, ga
    Regarding Question #1: If something like the minivci is the best tool then I could pick up a cheap / used windows laptop. I'm just looking for what my options are.
  5. Patrick Wong
    18,200
    6,474
    Mini VCI is the best diagnostic SW. Buy a Windows XP or Windows 7, 32 bit OS laptop to support it.
  6. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    Yep, $20 or so for the Mini VCI and $75 or so for a decent old laptop on Craiglist got my garage set up for the Gen 2. Bite the bullet and get one MS product. Or ask around, as lots of folks have these as doorstops.
    Mini VCI is not extremely robust, and has no documentation, but when it works and you can figure out the menus, it's very powerful.
    How old is the 12V, and what's the voltage at the battery or jump terminal after resting overnight? Then check in IG-ON, then Ready. If much under 12.2 V, the battery is getting old. If under 12, that's probably your problem--hope so.
    Ditto the above for a quick check at Autozone. They normally don't clear codes, and don't let them. If you get a replace hybrid battery code, contact Toyota for a goodwill contribution. You're very close to the warranty expiration and some have had some luck with this. You sound like a busy guy and replacing modules may eat up more of your time than you like over the next couple of years.
  7. ChapmanF
    15,616
    Somehow, a lot of the early-2000s Prius FUD lingers on in the ubiquitous assumption that "the worst" is going to have something to do with the battery. Out of various possible expensive Prius component failures, the battery is one of the easier to deal with. Meanwhile, the lights on your dash (your only information so far) stand in for literally hundreds of trouble codes for different problems ranging from serious to trivial. Just relax and get the codes read. :)
    They'll have to be read by a Prius-aware tool (such as Techstream) to get the hybrid-warning-light ones. Generic tools should pick up the engine codes, and might pick up the brake codes. There's also a toolless way to get the brake codes, but a scantool is easier.
    -Chap
  8. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    I agree the Mini Vci is a good tool to have and the price is OK considering it runs on pirated software.
    A quick test you could perform ( all the tools are on hand ), is on the Inverter Coolant Pump also known by Toyota as the 'Hybrid Electric Water Pump' to see if it has died of natural causes. The part box says " G9020-47031" "PUMP ASSY, WATER W/M" for a part dated 02/0217
    Let the car cool down a bit, remove grille top cover, make 'Ready', wait for the ICE to shut down and check for turbulence in the air separator/tank.
    Locate the Pump and reach down and touch it, if you can there should be a small amount of vibration felt and hear a hum in the drivers seat when the ICE is off.
    There was a recall in 2013 to change out the pumps in Gen2 2004-2007 and could have been extended to go all the way to 2009 as they all were identified as failing early. The dealer may do this for free if you have not done so during the recall but will not a second time.
    You may want to do a search.
  9. John Casteel
    22
    Savannah, ga
    I always assume the worst because that is just my personality. Then I test and hope for the best.
    Autozone found no codes. So I need to find a Prius aware tool? Do any of the autoplaces have this (call around?) or is this only a mini vci thing? I have seen a discussion that dxdiag is better than mini vci. Is it? Does it matter? Quick check on craigslist shows lots of Windows machines with windows 8 or 10. Is there a mini vci that works with later version of windows? I'll start looking.
    I am reasonably certain that the Inverter coolant pump was replaced on recall. Wait a minute let me go and see... "PUMP ASSY, WATER" (note without the W/M) was replaced in 2014 but it looks like they charged the previous owner.
    The 12v battery is 5 years old this month. Testing it through the MFD (following DIYprius test procedure) I get 12.3 v in ACC mode. 11.9 v after putting on a current load then 11.4 with headlights, rear window defroster and heater fan on. In ready mode I'm back up to 14.3. Is there any value checking it with a multimeter?
    I'd call that just above borderline but this is sunny coastal georgia and at 5 years old it is probably time to replace the 12v battery. I don't want to just start replacing parts but with the 12v I'll be lucky if it lasted through another summer anyway.
    If I want to avoid the dealership it looks like I need to get mini vci and a computer. Then proceed.
    If I went ahead and replaced the 12v hoping that that is the problem. Will the lights go off on their own or do I need something to clear them anyway.
  10. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    this was my answer to another post, but use it if it works for you
    sounds like Batt but another issue that lights up the lights is Brake Actuator which is extended on coverage. Can't recall if 2004 has the actuator issue.
    https://priuschat.com/posts/2353425/
    You can always try to ask Toyota USA for Goodwill warranty assist on Battery, chances iffy but we've been surprised before and NJ is CARB so sometime CARB states get more favor.
    https://priuschat.com/posts/2507664/
  11. ccdisce
    259
    187
    Stone Mtn GA USA
    You may want to confirm that the 'Inverter pump' is working now by looking for eddies in the separator/tank as the replacement Inverter. Replaced pumps have been reported to fail with the owners having to pay for replacement of the recall replacement.
    If there is no eddies in tank the fuse could be blown. The fuse can be blown by the pump failing to a shorted condition.
  12. andrewclaus
    993
    324
    Golden, CO
    The 12 needs to be replaced and that may solve all your problems. 11.8 V on an AGM battery is essentially discharged. The 14 V in Ready means the charging circuit is working just fine.
    Current codes will reset when the offending parameter is fixed. Some codes require a "drive cycle" to be completed, and I'm not sure what that is on the Prius. Some cars are pretty involved, and may take a few trips at different speeds.
  13. andrewclaus
    993
    324
    Golden, CO
    It's good news Autozone didn't find codes. They usually can get the big ones like hybrid failures. What you may have is probably a load of low voltage concerns on various ECUs.
  14. John Casteel
    22
    Savannah, ga
    I thought I had good news but first.
    I checked and there is turbulence in the coolant tank and I feel a vibration at the pump.
    I replaced the 12v. Started her up and the dash lights were gone. Yeah! I took the old battery to AutoZone for the core exchange and when I got back in the car the lights were all back on after starting her. I drove around for about 20 minutes hoping that the new battery needed a charge but that didn't change anything. I'll put the trickle charge on tomorrow and cycle the car through some startups and shutdowns. I think it is time for an old PC and the mini vci.
  15. Stevewoods
    Stevewoods Senior Member
    648
    993
    Seattle, WA
    If you register on the Toyota owners Web site, you can see what, if any, recalls have been performed, including the inverter.
    Personally, I would check the 12-volt after the car has sat for 8-12 hours, Use a multimeter at the jump points under the hood.
    #15 Stevewoods, Mar 9, 2017
  16. jdenenberg
    jdenenberg EE Professor
    3,852
    1,847
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Disconnecting the 12v battery resets many of the codes (not all). Real failures will then return as you drive. Try another reset after you charge the 12v and see if the codes return again.
    JeffD
  17. ChapmanF
    15,616
    I'm sorry you had to go through that; you've posted (another!) example of the real costs, both in money and lost time, of this persistent PriusChat notion that any codes no one has bothered to read or diagnose probably mean you need a new 12 volt. (The voltages you posted earlier were perfectly fine, considering what the MFD sees is a good fraction of a volt lower than right at the battery, and it's expected to drop under load.) So you spend the money on a battery, and take the time to put it in, and feel the temporary relief at the lights being off (since changing the battery wiped memories), and only when they come back on can you get back to solving the problems.
    Anyway, it's just time to get back to real diagnosis and get the codes read. This thread has already mentioned two of the possible causes for those lights to come on. That only leaves about 698 more, which the codes will immediately whittle down for you to a small likely set.
    Techstream is the best way to be sure of getting the codes from all of the ECUs capable of reporting them. If you're waiting on a Mini VCI and looking for something to do, you should be able to get the blink code versions from the brake ECU just using a wire (see many other threads for details). (Sometimes, the code in the brake ECU will just be the C1259 saying another ECU informed the brake ECU of a problem; in that case, it doesn't tell you much until you hear from that other ECU.)
    -Chap
  18. Stevewoods
    648
    993
    Seattle, WA
    Personally, it sure sounded like 12-volt problem. But I would never replace without checking the actual voltage after a several hour resting period. And, I would not rely on the MFD. Only real way to do it is on the actual battery or at the jump point under the hood....
    Having said that, his battery was five years old....
  19. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,916
    Columbia, SC
    Considering the car is still driving, sounds like very early stage of hybrid battery failure. The car I have right now went through very similar symptoms last month with the previous owner. It will be drivable, but will get worse and worse as the days go by. Mine is a 2007 Touring with 140k miles. I installed Gen 3 modules (all tested >6000mah) in the 2007 case and right now I'm still on my first tank of gas. 285 miles and still have 4 dots on gauge. Averaging 49.3 on the MFD. 23 miles each way to work, 5 day a week. 3 minutes of 25 mph zones, 10 minutes of 40-45 zones to get to highway, about 14 minutes of 55-65 mph highway and then about 2 minutes of 35 mph zones. Of course, I'm just like everyone else and go "hammer down" mode on the highway
    Looked at my data sheet and needed to make some corrections. Guess my memory isn't what it used to be. The original battery modules are being tested right now. Initial voltage checks showed one cell around 6.3v, one at 6.1v, one at 7.0v and the remainder at ~7.55 to 7.76v So far all modules have cycled and tested >6000mah, except the one that was 6.3v. It was cycled 5 times and capacity maxed out at 2013mah. Although the 6.1 and 7.0 modules recovered to 6300+ and 6000+ mah, I suspect they have some significant self discharge rates and will be monitored long term for further testing.
    Maybe you'll be lucky and have a similar problem. Easy to fix. If it is the battery, and you're bored and want to come to Columbia, I'd be happy to help you out.
    #19 TMR-JWAP, Mar 9, 2017
  20. John Casteel
    22
    Savannah, ga
    Yes, I may have jumped the gun on the 12 v but it was 5 years old. So maybe I would get 1 or 2 more summers out of it. The most years I've ever gotten out of a battery in Coastal Georgia (100% humidity and 3 months of 96* temps) was 7 years in a Miata. I did check with a multimeter and the numbers were a few tenths lower in all cases except while in ready mode and charging. So I don't feel, in this case, that I threw good money after bad.
    Chapman F you make a good point and if the battery were 3 or 4 years old maybe I would have done differently. But in my case I didn't feel that it was a risk. I won't lie that I was pretty euphoric when the dash was clear driving to the AutoZone. And then aeuphoric during the return home.
    As mentioned I have quite a few nights of work ahead of me and then a long anticipated 4 day vacation with my 12 year old daughter (first time for her on a plane and first time to NYC). The two of us have had a tough 3 years dealing with other issues and a car isn't worth ruining her first real vacation. I'm not going to let this get me down or stand in the way of a good time. I'll deal with it when I get home but that is not to say I won't do a few things in the meantime. Namely ordering a mini vci and locating a PC. Before becoming a nurse i worked on computers for 20 years. I used to have stacks of the things available to me. Now, for want of a nail the war was lost.
    Thanks for all help so far. I don't know about coming to Columbia but I'll keep that in the back of my mind.
    andrewclaus and jerrymildred like this.
