Tools for Headgasket Replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by BeanieBoo, Dec 7, 2025 at 6:22 PM.
  1. BeanieBoo
    BeanieBoo New Member
    Yesterday
    Alabama
    Hey Prius Cult!
    I’m just a few days away from diving into my first head-gasket replacement on my 2013 Gen 3 Prius. This car’s various “adventures” are what made me realize I actually love auto mechanics — enough that I’m seriously considering a career change. I’ve spent the last few months researching everything I could get my hands on, watched all the Gasket Masters videos, and I’ve got the Haynes manual in both digital and paper form. All my parts are here and ready to go.
    Before I get started, I want to make sure I’ve got every tool I’ll need. My tool collection grows with every project, but building a full mechanic’s setup takes time and money. Once I begin, I’m not coming up for air until the head is off, sent to the machine shop, and the car is back on the road.
    If anyone has a solid “don’t start this job without these tools” list or any last-minute advice, I’d really appreciate it. I’ve got a touch of the tism, so having a clear list really helps me organize and consolidate my thoughts.
    Please and thank you!
    PriusCamper likes this.
  2. PriusCamper
    PriusCamper Senior Member
    12,748
    5,156
    Pacific Northwest, USA
    Welcome to PriusChat!
    We could really use a dedicated thread to headgasket repair. It'd be awesome if you could blow this thread up with everything you've studied because there's lots of us who have been wanting to get into doing this particular repair due to so many people needing it.
    Of course because you're new hear you'll be moderated for your first 4 or 5 comments before you can share images and links. So make comments on other posts on the site so you can get this thread going!
    Also I bet @Mendel Leisk and @chapman will help us build the ultimate thread for Gen3 headgasket repair!
    And beyond this post and this one headgasket job, you could make good money specializing in Prius repairs and working for yourself... Most shops charge so much for repairs that you can make big money working for 1/2 of what they charge.
    #2 PriusCamper, Dec 7, 2025 at 8:29 PM
  3. indel
    indel Member
    88
    31
    Northwest Indiana
    Agree with @PriusCamper about a master thread on headgasket repair. The conventional wisdom I keep hearing on Priuschat about head gaskets is that it is hardly worth doing that job because of the tight tolerances that the engine was designed with. Even if you do the gasket, the problem might come back again, or the timing may be off due to decreased depth of the engine after head resurfacing, so on and so forth. I do not know how much faith to put in either of those, nor will I ever attempt to tackle this job myself having watched the GasketMasters videos.
    Nonetheless, I am rather curious about how diy this job is and if it provides long term reliability.
  4. PriusCamper
    12,748
    5,156
    I know too many people who need this job done and I keep learning about it and then something comes up that I had not yet learned and I get a little intimidated about it all yet again. I'm sure once I've done a couple of them I'll wonder why I was ever intimidated by the job, but I ain't there yet.
    indel likes this.
  5. Mendel Leisk
    41,427
    Last link in my signature is the full engine section, from the Toyota Repair Manual. (on a phone, turn it landscape to see signatures)
    Don't get misled by Gasket Master's recommendation to use a "triple-square" bit for the head bolts. The correct tool is a 10 mm double hex, which is readily available on Amazon, and likely local to you, at automotive specialty stores. Seems like it's easier to find on amazon.ca than amazon.com, but anyway, here's a direct link, for both the 8 and 10 mm drivers, from one manufacturer (CTA Tools).
    Gasket Master’s mention of Permatex Ultra Black (as a form-in-place gasket) is good though: while not what Toyota specs, it's effective, and has a much more leisurely cure time. The only downside, it's recommended to wait 24 hours before adding oil and firing it up.
    If I was in your shoes (pray I never need to do this....), I'd go for the Toyota overhaul gasket kit: it's got most every gasket, o-ring and seal you'll encounter, all genuine Toyota, plus the head gasket of course, and the head gasket has had a revision, so hopefully good for the duration. I've a hunch the original head gasket's bad rep was in fact a clogged EGR system problem, but that's for another discussion.
    The Gasket Master's videos are good, but from the perspective of a time-limited pro; you'd do well to also watch priuschat member @NutzAboutBolts’ three-part series. Which you can find linked at the bottom of first post here. All the other videos linked there invaluable as well, in particular the preceding engine and inverter water pump replacement videos.
    #5 Mendel Leisk, Dec 7, 2025 at 9:56 PM
    PriusCamper and NutzAboutBolts like this.
  6. rjparker
    rjparker Tu Humilde Sirviente
    10,139
    6,300
    Texas Hill Country
    IF the engine was not burning oil AND it never overheated AND the hg leak was diagnosed quickly before coolant loss AND no time was wasted for egr cleaning or new plugs, THEN the odds are the head does not need resurfacing, the block is not warped and a head gasket job might last 50k miles.
    Will a dealer do a hg job? Not likely because of comebacks and high cost. Is a Hayes manual adequate? No. Is timing a common diy fail? Yes. Can an experienced and skilled mechanic get it right the first time? Yes if they accept the job.
  7. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,695
    1,740
    Bay Area
    All the tools is listed in my video description. The job itself isn’t too bad, the first time will take the longest to figure out where everything is at, after you do this 3-5 more times, you’ll be a natural at doing this job and can finish it quickly in a couple of hours… that is if you’re just doing the minimum work.
