Top Engine Clean - How to Feed Liquid Into Motor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Pollymath, Mar 11, 2020.
  1. Pollymath
    Pollymath Member
    102
    37
    Flagstaff, AZ
    The head on my 2010 is pretty cruddy, so the EGR Cooler/Pipe/IM cleaning will be well worth it.
    What also bugs me is the amount of crap around the valves and on top of the pistons (viewed via scope).
    Has anyone tried a top engine clean like we used to do on older engines, where you put a vacuum hose into a can of GM TEC, suck the can empty while trying to keep the motor running?
    mjoo likes this.
  2. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    The trick I would try is Seafoam Spray. It has a 8-12 inch hose, along with a piece of molded plastic. You clamp the plastic with the hose on the throttle body using the clamp for the intake hose. Then an assistant keeps the car running (Power mode in Maintenance Mode) so you can maintain 2k RPM. It takes 7-10 minutes to empty the can. Take the car out in the middle of nowhere, as it gets very smoky.
  3. ChapmanF
    17,348
    Does this send chunks of carbon rattling down into the catalytic converter?
  4. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    None of the other 4 cars that I have used this method on have suffered any lasting ill effects. They do smell until you take them out the highway for a couple of miles though. LoL
  5. toobz4this
    toobz4this Junior Member
    North Carolina
    I had a top engine clean done on my '08 and then the check engine light came on and the tech said the Catalytic converter is bad. Car was fine going in for oil change came out with needing converter replaced. I was angry and told them that they broke it doing the engine clean. So now I am stuck. Is there anything I can add to the fuel to clean the catalytic converter? I had someone tell me to put about 3 gallons of racing fuel in the gas tank and it will burn the crud away. I hesitate to do this without chatting it out with you all. BTW, my Prius has over 200K miles, runs great, gets 45mpg. I cannot afford to replace the converter, part alone was going to be $2200.
  6. Peter123
    Peter123 Active Member
    131
    128
    Cataclean claims it will clean your catalytic converter. Add two bottles to half a tank of fuel and go on a road trip with lots of high speed driving. Or the alternate method is add a gallon of acetone to a full tank and then do the road trip. Some people have better luck with cataclean than others, that is why I think two bottles works better.
    Cataclean - Fuel & Exhaust System Cleaner
  7. mjoo
    mjoo Senior Member
    1,147
    1,326
    Michigan
    I also had
    after doing the EGR system cleanse. It looked bad enough that I was afraid of knocking off a chunk and having it ricochet around the engine or get lodged in a valve. What cured it: a few bottles of Techron concentrate and time. After a couple of years I removed the intake manifold to clean it again and the head was void of carbon deposits with a light oil coat.
    Some of the fuel injected gets belched back into the intake manifold during the Atkinson cycle of the 2zr-fxe engine. It makes fuel system cleaner very effective against this sort of thing.
    wheezyglider and Raytheeagle like this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Yours was also used as an experiment:whistle:.
    But at least it is sorted(y).
    mjoo likes this.
  9. mjoo
    mjoo Senior Member
    1,147
    1,326
    Michigan
    Unprofitable experiments are forgotten while profitable ones continue (see my sig)
    Ray, thanks for the Hybrid Automotive suggestion!
    Raytheeagle likes this.
