Topping off coolant tanks
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jonny Zero, Aug 9, 2014.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    What do you use? Distilled water or Toyota Super Long Life Premix?
  2. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Maybe we should talk briefly about how full they should be.
    There is some room for expansion needed and should not be totally "full".
    If only a couple of ounces is required, where you live either should be fine.
  3. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Actually, you should not have to top off. If you are losing coolant, more than likely you have a leak somewhere. But in answer to your question, you should always use the Toyota Super Long Life Coolant. Adding water to the system dilutes the coolant and lessens the protection levels that are necessary for the proper operation of your Prius.
    Ron (dorunron)
  4. Mendel Leisk
    38,709
    Our levels are slowly going down. Not leakage, I think. More likely just evaporation. I'd concur: pre-mixed coolant. Would be nice if you could get a quart bottle... Maybe if you're DIY but ask nicely at service, they'll give you a pint?
    While I'm doing my own oil and transaxle changes, I've pretty much made up my mind to let them do the coolant change (if I ever get there), so I don't want to be lumbered with most of a 4 liter container of the stuff.
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Thanks for the inputs. I am talking about a couple of ounces to bring the levels back to the full mark. Pretty sure it is just evaporation in 2 years and 40K miles...
  6. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    I got a bottle of the Toyota coolant, but I regret that I put in some water once, before I got the coolant.
    dorunron likes this.
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    IIRC coolant exchange of the inverter circuit is a little less than a gallon.
    As for the engine coolant circuit, I plan to replace a gallon every year/10k miles once the car reaches 80k miles. With a Lisle funnel I can avoid introducing air and the subsequent hassle of burping the system.
    So a gallon container is actually a practical quantity ;)
  8. Mendel Leisk
    38,709
    ^ Are you thinking to avoid an all at once change thus?
  9. Easy Rider 2
    1,584
    257
    Ocala, FL
    I don't think you should regret that too much.
    IF the loss really is just evaporation, the only thing you are losing is the water component.
    I'm pretty sure that the coolant itself doesn't evaporate easily.
  10. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    Well it wasn't evap I had the typical water pump leak but now it is holding
    Gotta get me one of those li'l funnels...what is it?
    #10 wjtracy, Aug 10, 2014
  11. SageBrush
    11,627
    2,530
    Southwest Colorado
    Exactly. Or perhaps make it a once in a car lifetime annoyance. I'm not yet positive exactly in what manner coolant is 'old.' Does it mean contaminated, or does it mean protective chemicals have been used up ? If the latter then I'll just refresh a fraction periodically.
    Lisle funnel. Google for an internet purchase, although I bought mine at a NAPA store locally. I think it cost $45, and it is worth every penny.
    #11 SageBrush, Aug 10, 2014
  12. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Check the PH. If PH is spot on then you should be fine. Check yours as well as ours should be spot on as well? H
  13. SageBrush
    11,627
    2,530
    Southwest Colorado
    I agree that if the fluid is acidic or turbid it is time to change, but I'm not sure if that is enough.
    addendum: To clarify, I am unsure about the converse: I don't know if both pH and turbidity are within tolerance, if that is enough to say that the coolant can continue to be used.
    #13 SageBrush, Aug 10, 2014
  14. dorunron
    3,318
    1,103
    Houston, TX
    Agreed on the PH Level. Also if the fluid has changed color from original, it is a good indication of contamination. Best to sample a fresh batch of SLLC to establish a baseline for the PH level, and the color of the fluid. The only other thing that comes to mind would be to run a sample through a lab for analysis while also furnishing a sample of fresh SLLC for comparison purposes. I also agree that the Lisle Funnel is the tool to have for those who are working with coolant changes. Less expensive than a air lift and seems to work better than a air lift. Plus there is no squeezing of hoses unlike with a airlift tool.
  15. SageBrush
    11,627
    2,530
    Southwest Colorado
    Hobbit wrote about engine coolant during his '100k' mile maintenance. His coolant was 150k miles old and had turned orange colored, but still tested pretty well by pH.
  16. Mendel Leisk
    38,709
    What I'll likely do is buy a gallon, top up the reservoirs, then when replacement interval comes up get the pros on it, and bring in the remainder. Maybe they can use, or at least recycle.
    #16 Mendel Leisk, Aug 10, 2014
  17. dorunron
    3,318
    1,103
    Houston, TX
    I do recall that "sage". It would be interesting to run a chemical analysis of the used coolant and compare to the new. That would be the tell all for sure.
  18. Easy Rider 2
    1,584
    257
    Ocala, FL
    Not sure what is "enough" ??
    Draining out a bit and putting partial fresh only addresses part of the age problem.......depleted additives.....but not the other problems of chemical changes creating bad stuff and possible "grit" creation and accumulation.
    A partial exchange is little better than just leaving it alone.
  19. SageBrush
    11,627
    2,530
    Southwest Colorado
    Right. Whether those two variables alone tell us when to change coolant. "Grit" will make the solution turbid. And as for "bad stuff," you will have to be more specific and show that serial dilutions leave too high a concentration if you want to taken seriously.
    As for your other dogmatic statements, do you have any objective data ?
    #19 SageBrush, Aug 10, 2014
  20. Easy Rider 2
    1,584
    257
    Ocala, FL
    Give it a rest please.
    Like everyone else here I am stating my considered opinion, garnered over about 50 years of experience.
    I think the fact that ALL car makers recommend changing the coolant out COMPLETELY at some point in time, usually accompanied by a simple flush, is proof enough to me that other "plans" are either not effective or not necessary.
    If you think the recommended change interval is too long, then change it earlier.
    Do you use the "partial replacement" method for engine oil and brake fluid ?
    If not, why not ? (No answer required; rhetorical question.)[/QUOTE]
