Torino Air Horn added to Prius C (pics and video inside)
Discussion in 'Prius c Accessories and Modifications' started by Lockdown Security, Jun 23, 2012.
  1. Lockdown Security
    Lockdown Security Junior Member
    Hey Everyone
    Just added a Torino Air Horn to my Priuc C as I was not very impressed with the OEM horn sound. It was an extremely easy modification and no wires were cut or holes drilled to install this horn.
    The horn I used was the Torino Euroblasts Twin Chrom Horn (we sell it in our online store @ Torino Euroblasts Twin Chrome Horns - 139db - FREE SHIPPING) and using a piece of steel backstrap, a small length of 12 gauge wire and some electrical connectors I was able to install this in under 15 minutes.
    Only thing I had to do was bump the OEM horn fuse up by 5 amps (not safe to go any higher) to factor in the slightly higher load the air compressor will draw. I did not install an aftermarket relay as the OEM wiring and OEM relay will suffice as long as the horn is not activated for extended periods (more than 1 minute say) at one time. If I decide I would like to activate the horn for longer periods of time (not sure why I would) then I would install a relay.
    As you can see in the pics, the horn fits perfect right in the centre of the engine bay along the rad support, and because the casing is chromed it looks pretty cool there!
  2. priusCpilot
    priusCpilot Active Member
    631
    209
    LA
    I have the bad boy horn that I wanted to install in the OEM location but will need to remove the bumper or lower bumper cover to access it. What a difference and air horn makes!
  3. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    holy crap!!!!!!!
  4. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    i would have gotten the wolo badboy air horn. installing a relay will not only protect your wiring but will also slightly increase the sound power of the horn. thanks for the video!
  5. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    The one thing I'd worry about with an air horn is the "spool up" time of the compressor. It doesn't seem to have a sharp attack, if you know what I mean.
    That would be a good reason for installing a relay.
  6. kingnba6
    1,018
    242
    NY
    the "spool" time is almost nothing! i have a wolo badboy on my bike and its maybe like a half second delay for the horn to get energized. this only applies to the horns like the OP has and the wolo badboy, but if you install one with a separate compressor then that would need to have power all the time in order to stay energized.
  7. FastZX6R
    FastZX6R Junior Member
    I have a Stebel Nautilus on my motorcycle and like the previous poster said the horn is on instantaneously there is no appreciable lag.
    Love my Stebel Nautilus! Much better then the dumb road runner beep beep on our cars!
  8. karabits
    karabits Member
    51
    Minneapolis
    Nice pics and vid. It appears the horn is installed facing toward the driver/passengers. Does this configuration cause the horn to be excessively loud from inside the car and noticeably quieter for vehicles in front? Is there a fix in the pipeline for this? Thanks!
  9. Lockdown Security
    Where the horn is mounted hasn't affected the horn's output at all, you can hear it perfectly outside and as normal on the inside.
    karabits likes this.
  10. karabits
    karabits Member
    51
    Minneapolis
    Excellent. Have you experienced or are you concerned about dependability issues related to heat, as the horn is mounted behind the radiator? Thanks again.
  11. Lockdown Security
    No heat concerns or reliability concerns, the rad doesn't put out enough excess heat to effect the horn. It's been working perfect for almost a year now, no issues at all.
