Torque Pro-Veepeak-Apple phone
Discussion in 'Gen 3 Prius Technical Discussion' started by Phil Yaden, Apr 24, 2022.
  1. Phil Yaden
    Phil Yaden Junior Member
    22
    johnson
    Has anyone used Torque pro with Iphone and veepeak bluetooth. I cant seem to connect to the bluetooth. Any thoughts?
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,824
    6,063
    Texas Hill Country
    My understanding is Torque Pro only works on Android. I use Dr Prius or Car Scanner with IOS. Both will read and clear common codes and read high voltage battery data. Dr Prius focuses on the battery.
    Techstream or XTools D7 or D8 are the best scanners for Toyota advanced requirements. Not free.
  3. Phil Yaden
    22
    johnson
    I have DR Prius...but it only shows a P3000 code ...need the rest...Car Scanner needs ELM
  4. EH6TunerDaniel
    55
    29
    I also use a Veepeak but i use OBD Fusion.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,009
    1,943
    NJ-USA
    You might want to look at the Autel Maxi AP200 bluetooth device and app. Their site says it works on android and ios. For my Gen2 it had access to ALL codes and data for ALL systems- including freezeframe and INF detail codes.
    ColoradoCrow likes this.
  6. Wobblybike
    Wobblybike Junior Member
    23
    Los angeles
    I do! It’s the obd2 set up. Check it and re set up. Mine took a couple setup to get it going. Hope this helps.
  7. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    462
    Leawood, KS
    I
    Looks like $49 on Amazon. But there are several different ones.....which model did you buy?
  8. Wobblybike
    23
    Los angeles
    Torque pro does not work on IOS it works on android. I use Car Scanner on ios. Works fine with Veepak 4.0
  9. mr_guy_mann
    4,009
    1,943
    NJ-USA
    I got the "plain" Autel AP200, NOT the C, H, or M variants.
