Torque Pro with BAFX OBD2 Scanner not working - please help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by LoveourPrius, Dec 29, 2023.
  1. LoveourPrius
    LoveourPrius Junior Member
    When I first used Torque Pro with a BAFX ANDROID OBD2 Scanner, over a year ago, it worked perfectly. It read the HV modules, temperature sensors, cooling fan speed, Aux battery SOC, etc.
    Now it will read the Revs, Coolant temp, Fault codes but will not read and of the battery PIDS. I removed and recreated the car profile, and I tried the Torque Pro with BAFX OBD2 Scanner on 3 different cars but it behave the same with all 3 (Gen 2 and Gen 3) Prius.
    Please help. I need to diagnose a P0A80 fault code.
  2. john1701a
    john1701a Prius Guru
    12,753
    5,245
    57
    Maybe something changed with Torque. Try a different app, like Car Scanner.
    #2 john1701a, Dec 29, 2023
  3. LoveourPrius
    Thanks John. I appreciate your help.
    I looked at a couple of videos on Car Scanner, but could not see if it displays the min and max voltage on each module in the high voltage battery?
  4. john1701a
    12,753
    5,245
    57
    For some perspective, I jumped into my wife's Prius Prime to see what detail I could pull with its Car Scanner profile.
    I got all 96 individual cell voltages and the average for each stack (packs 1 to 4, as shown), but not Min & Max like with my bZ4X. Screenshot_20231229-215746.jpg
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,430
    1,484
    NJ-USA
    If I remember correctly, you have to "enable" added Gen2 data for Torque Pro in some submenu.
    Or you could use Dr Prius with your BAFX.
