Torque setting for strut bolt??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mypriuscious, Apr 4, 2016.
  1. mypriuscious
    mypriuscious Member
    217
    70
    Cincinnati, Ohio
    I have found conflicting information. One post says 177ftlbs. And others say 47 ft lbs. Even then the wording is kinda jumbled.
    Does anyone know what the center bolt on the strut is supposed to be?
  2. Mendel Leisk
    40,241
    Looks like the two bolts at the bottom (kind of clamping) are 177, and the central top bolt is 35.
    mypriuscious likes this.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,326
    CA
    Be sure to tighten the center nut after the vehicle is back on the ground (with the struts installed). The upper mount is keyed so the shaft will not spin when you tighten the nut. If you only tighten the nut when the strut is mounted on the compressor, you will probably undertighten and be puzzled by the strange knocking sounds.
    SDB54 and mypriuscious like this.
  4. mypriuscious
    mypriuscious Member
    217
    70
    Cincinnati, Ohio
    Thank you guys so much!
  5. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,497
    1,590
    Bay Area
    Looks like the Center bolt that goes to the top strut is 47 ft. lbs, and the 3 bolts that bolt the strut to the frame fender is 37 ft. lbs. The bottom strut that bolts to the hub assembly is 177 ft. lbs.
    Robert Holt likes this.
  6. Mendel Leisk
    40,241
    Double check me, but I think the central top bolt is 35 lb/ft. (47 the metric value)
    CR94 likes this.
  7. NutzAboutBolts
    1,497
    1,590
    Bay Area
    You're right, I saw 47 for the ft. Lbs for some reason. It is 35 ft. Lbs
  8. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    I just want to make sure about the center top bolt. I bought the already put together struts. There's a cover over the center area.
    Do I need to remove it and tighten the bolt, or has that already been done?
  9. Patrick Wong
    18,200
    6,490
    It just takes a minute to remove the cover and check the torque on the center nut, so you should do that.
  10. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    Yes, did it today. The entire job wasn't as bad as I thought. Those lower strut bolts were a challenge, but finally got them off. Pretty sure they were never removed before.
    Really, getting the wipers and cowl stuff off is the most work I thought.
    Ride is much better for sure. Now for the rear. Thanks for all the info!
  11. The Critic
    3,193
    2,326
    CA
    Be sure to get an alignment.
    SDB54 and Raytheeagle like this.
  12. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    Yes, I can feel it pull just a little to the left. I still may do the rear shocks, so should I wait on the alignment until after I do them?
  13. Patrick Wong
    18,200
    6,490
    Yes, wait until you are done working on all four corners. The front wheel alignment partially depends upon the thrust angle associated with the rear axle.
    Robert Holt and SDB54 like this.
  14. MrDan
    MrDan Junior Member
    37
    Pomona
    Hey guys i just found this thread! im doing my front struts This weekend and i just ordered the struts online. I wanted to know if i need a air impact gun or can i get away with using an impact driver like the battery powered ones?
  15. prius2go
    prius2go Member
    312
    If you have the car jacked up, can you just undo that centre bolt and drop the strut enough to get to the rubber shock cover?
    Or is the spring still under compression when the car is jacked and you undo bolt ?
