Torque settings when changing battery module
Discussion in 'Gen 2 Prius Technical Discussion' started by Peterhans, Jan 13, 2022.
  1. Peterhans
    Peterhans Junior Member
    103
    Germany
    I found a procedure for changing the battery module on the prius hybrid 2006. Within the procedure there are torque settings for certain bolts. However, on the video there are no comments referring to torque settings. Any suggestions?
  2. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    What procedure? What video? I can read your post, but I can't read your mind.
    Peterhans likes this.
  3. Tombukt2
    Tombukt2 Senior Member
    12,214
    2,155
    Durham NC
    In the old days before I had all the big money and bought all the fancy tools I tried to put stuff back the way I found it so as much oomph as I had to use to undo it I tried to put it back to that same oomph. I built engines like this for a few years none of them ever flew apart not saying that's the way to go but if you're only going to do this once or twice in your life wella.. The battery case end plastics and the 12 mm that sandwiches the modules together they were tight AF I couldn't believe 12s would be whacked down that hard
    rogerdpack and Peterhans like this.
  4. Mendel Leisk
    40,584
    might be in this:
    rogerdpack, AndyFromWI and Peterhans like this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    The most important fasteners are the individual module terminals where the busbars are installed (48 INCH-pounds), the fasteners under the battery that lock the modules to the case (48 INCH-pounds) and the nuts that connect the main orange cables to the relays (48 INCH-pounds). So....anything that has an 8mm hex head=48 INCH-pounds.
  6. Peterhans
    103
    Germany
    I will upload this.
  7. Peterhans
    103
    Germany
    This is correct.
  8. Peterhans
    103
    Germany
    See the answer below by Mr. Leisk.
