Torque specification for the inverter wires bolts on the 2012 Prius C? [and brake lines]
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Sonic_TH, Feb 14, 2021.
  1. Sonic_TH
    Sonic_TH Active Member
    545
    88
    Puerto Rico
    I have tried to search for the torque specification of the bolts on orange wires that connects to the inverter / converter from MG1, MG2 and the hybrid battery but seems like such information does not exist. If someone knows please share it in the comments below, i'm replacing the ABS actuator and i would like to tight the bolts to the specified torque if possible, same goes for the brake lines, if these even have torque specification.
  2. PriusCamper
    PriusCamper Senior Member
    11,105
    4,518
    Pacific Northwest, USA
    They do have universal charts for torque based on bolt & thread size... I suspect there's probably a website that will give you that info. Main emphasis with torque being the tightness for optimum strength, though there are other purposes for moving parts.
  3. ChapmanF
    15,630
    Do you mean that it doesn't exist in the Prius c repair manual, or that for some reason you thought you should not look there?
    Please don't assume these are the same: this is from my 2010 (not a c) repair manual. But it should show you what you are likely to see in the c repair manual (more info) if you turn to where inverter removal/installation is covered.
    Those should also be easy to find in the manual.
    Right, the universal charts are usually for a few certain types of bolts/nuts graded for structural use. For a specific use like electrical terminals (as here), the fasteners might be made of different metals or alloys that the universal charts don't cover, and the specified torque might be chosen for some reason other than maximizing the joining force. For example, in some applications (with cup washers, say), you definitely don't want the torque that maximizes the joining force.
    In general, you would want to resort to a universal chart only when you really do find that there is not a specific torque specified in the repair manual.
    #3 ChapmanF, Feb 14, 2021
  4. Sonic_TH
    545
    88
    Puerto Rico
    It seems like such manual is not free online for everyone to have access to it right?
  5. ChapmanF
    15,630
    One answer: in the wiki page that Elektroingenieur compiled, there are numerous options covered for getting access to the manual, and some of them are free in some areas.
    Another answer: maybe you are someone who philosophically believes you should never look anywhere but free sources even when you know what source contains the information you need. I can even sympathize with that, but then it is more upfront to not post "seems like such information does not exist", but rather something like "I have chosen not to look where the information I need is, because that would conflict with a personal philosophy, so I would like someone else to look it up for me."
  6. PriusCamper
    11,105
    4,518
    Yes it is free information... Just as every bolt has a size and thread type, it also has a standard torque number where its holding strength is at its best. This is most common in bridge and other engineering design processes... I've seen the chart before in a repair manual back before we had the internet. I'm sure if you search you'll find it online.
    Sonic_TH likes this.
  7. ChapmanF
    15,630
    An important point, made earlier, is that the "standard torque number" derived from holding strength is published for certain classes of fastener made of certain alloys, and is reasonable to use when those fasteners are being used for mechanical joining purposes (such as in building a bridge).
    But there are lots of other applications of threaded fasteners, such as here for making current-carrying electrical connections, and for those applications the manufacturer may have chosen some different type of metal or alloy more suited to the purpose, or may have built the connection in a way that requires a different torque spec. (Connections with cupped washers, for example, made to keep a steady clamping force across expansion and contraction, can't be overtorqued, or the washers get flattened.)
    That's why it's important to first look in the manufacturer's specs (here meaning the repair manual) to see if there is a torque the manufacturer specified for that fastener in that application. Only if there is not, and it's a standard graded fastener in a mechanical joining application, then you can resort to the generic torque-by-size-and-grade chart.
  8. Sonic_TH
    545
    88
    Puerto Rico
    Yeah, if the bolt has a specific torque in the chart depending on bolt size and thread i guess i could use that one for the inverter covers. When i was taking the inverter wires bolts out they were torqued with quite a significant less torque, i could feel it, much easier to remove them, i'm sure that if i over torque it i can damage the threads or the connections.
  9. Sonic_TH
    545
    88
    Puerto Rico
    I know there is a chart that have the specifications by bolt size, but i would like to see what Toyota specifications are, for the electrical connection bolts.
  10. PriusCamper
    11,105
    4,518
    Torque on electrical connectors do exist, but only on some of them... So I wouldn't spend too much time worrying about it. Torque on engine parts is one thing, but not so much on others parts especially screws that hold down electrical connections.
  11. ChapmanF
    15,630
    On the other hand, #3 showed that there is an explicit torque called out for each electrical connection on the inverter for a 2010 Gen 3 in the repair manual, and there is very little reason to think that there are not such torques specified in the Prius c repair manual.
    In my experience, the repair manuals do most commonly give specified torques for everything. There is a generic torque chart by size and grade in the front portion of the manual, but there are very few fasteners anywhere on a Toyota where it would be used because an explicit torque isn't given for the specific fastener.
  12. Sonic_TH
    545
    88
    Puerto Rico
    I guess i will torque them to the specifications of the gen 3 Prius, i don't see why Toyota would change this, even if it did, i can't find the repair manual of the Prius C, i can't even find anything related to the Prius C inverter, brake actuator and brake booster in general [not free at least]. Since i will have to replace both the brake actuator and booster on my Prius C, i can't really spend money on manuals now, i do not have a good income and aside from this car, my father 2001 Sequoia have some issues too.
  13. Sonic_TH
    545
    88
    Puerto Rico
    I see, well thank you for the information. I will torque them to the gen 3 specifications, i can't take the risk of over torque them, since these are electrical connections the materials tend to be more fragile and easy to damage if torqued too much.
  14. Sonic_TH
    545
    88
    Puerto Rico
    I guess in that image, on the wires bolts connections, is 71 foot pounds? correct me if i'm wrong.
  15. PriusCamper
    11,105
    4,518
    Maybe you mean inch-pounds, because that much in foot pounds would be way too tight?
  16. Elektroingenieur
    2,515
    3,259
    Three Touring
    No, that would be twelve times too tight.
    The image shows the torque values—for a different car, as @ChapmanF pointed out—in newton meters (abbreviated N · m) and inch-pounds (abbreviated in.-lb. or in.-lbf.), twelve inch-pounds to the foot-pound.
    Toyota’s Repair Manual for 2012 Prius c cars (RM19C0U) says the torque for the high-voltage connectors (that is, those for the No. 2 engine wire, motor cables for MG1 and MG2, and frame wire) on the inverter with converter assembly should be:
    • 9.2 N · m (81 in.-lbf.) for the two bolts that hold each connector in place, and
    • 8.0 N · m (71 in.-lbf.) for the two or three bolts that make the electrical connections.
    PriusCamper and Sonic_TH like this.
  17. Sonic_TH
    545
    88
    Puerto Rico
    Yeah my mistake, it would be around 6 foot pounds.
  18. Sonic_TH
    545
    88
    Puerto Rico
    I see, for the electrical connectors is the same as the one in the gen 3 Prius. And what about the torque of these covers pointed by the red arrows? Thank you very much.
  19. Sonic_TH
    545
    88
    Puerto Rico
    Is there any tool to torque brake lines to a specific value?
  20. Leadfoot J. McCoalroller
    7,176
    6,722
    Pennsylvania
    2018 Prius c
    I suppose you could use crowfoot flare wrenches on a regular torque wrench if you had an adaptation factor for the longer arm. (Hmm, maybe offset the crowfoot by 90°?)
    To be honest I haven't ever run into a brake fitting that was so sensitive that (with experience anyway) you would not be able to do by hand.
