Torque specs for inverter high voltage wires?
Discussion in 'Gen 2 Prius Technical Discussion' started by sorka, Apr 10, 2021.
  1. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    Anyone of the torque specs for the two high voltage cables that have 3 bolts each inside the inverter? I'd rather not wing it on this one.
  2. PriusCamper
    PriusCamper Senior Member
    13,044
    5,299
    Pacific Northwest, USA
  3. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    Not sure your entire response made into your message :)
  4. PriusCamper
    13,044
    5,299
    I thought you were talking about Torque app, I don't know specs on those torques but as long as its not too tight you're good.
  5. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    ....or too loose;)
  6. PriusCamper
    13,044
    5,299
    It's 48 inch-pounds on battery pack nuts, aka: lowest clutch setting on my screwdriver gun.
  7. Mendel Leisk
    41,889
    I believe 71 inch/pounds (roughly 6 foot/pounds). From repair manual (excerpt attached):
    SFO, sorka and Raytheeagle like this.
  8. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    Thanks for that. Pulled the cover and checked the torque. They were all a hair under this already. I used my in-lbs 1/4 dial driver to retorque them.
