Torque Value?
Discussion in 'Gen 2 Prius Technical Discussion' started by Nice_Rumble, Mar 24, 2010.
  1. Nice_Rumble
    Nice_Rumble Junior Member
    New London, NH
    Anyone know what the proper torque value is for the oil drain bolt and oil filter? Doing an oil change soon and will need that information. I did look in the manual and could not find it.
    Thanks.:)
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    The answer for the oil filter is normally on the side of the filter. They will either say "hand tighten only" or "after the rubber gasket contacts the seat to make one complete revolution". Be sure to check for leaks after adding oil and restarting engine.
  3. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Oil plug - 28 ft/lb (38 Nm)
    Oil filter - 13 ft/lb (17.5 Nm)
  4. Nice_Rumble
    New London, NH
    Exactly what I was looking for. Thanks so much '09 Prius.:D
