Torque Wrench setting for 1NZ-FXE engine.
Discussion in 'Gen 2 Prius Technical Discussion' started by Mirza Murtaza, Jul 2, 2022.
  1. Mirza Murtaza
    Mirza Murtaza Junior Member
    Any body can guide regarding Torque Wrench Setting range for the tightening of bolts of Main Bearing, Big End Bearing, CamShat Bearing, Cylinder Head Bolts.
  2. Tombukt2
    Tombukt2 Senior Member
    8,929
    1,554
    Durham NC
    If you search in here you will find the 1NZ manual for the Gen 2 and that would cover the gen 1 for those torque specs I don't have them in front of me I just make them tight and let it go That's what I've been doing for 40 years so I own a torque wrench and still brand new in the box been used about twice haven't had anything fly apart yet so I'm not too bad there's aircraft mechanics here who will cringe at that but they're 5,000 ft off the ground I'm on the ground My dropper rod oops if they drop a rod not so much oops as dead Good luck buddy
