total newb battery question
Discussion in 'Newbie Forum' started by 2clicker, Sep 18, 2013.
  1. 2clicker
    2clicker Member
    114
    28
    St. Louis
    when i go through drive throughs i notice that even while stopped in P or in D (foot on brake) that my battery level drops very quickly. do i have to switch to Aux mode even for just a minute or two?
    another thing... my battery level never shows fully charged. at most it fills up to the last pip, but never full. is there anything wrong with that?
    JMD likes this.
  2. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Nope perfectly normal
  3. 2clicker
    2clicker Member
    114
    28
    St. Louis
    on both accounts?
    good to hear! it seems a bit much to have to switch into Aux mode while in a drive through, but thats what i will do i suppose. id like to keep the ICE running as little as possible.
    thanks!
  4. JMD
    3,779
    1,282
    The ice running is a good thing it charges the battery when it gets to low. The computer regulates the processes not wise to mess with it
  5. 2clicker
    2clicker Member
    114
    28
    St. Louis
    i know it charges the battery, but if keeping the battery level up by using Aux mode more will keep the ICE from burning fuel then im going to at least try it.
    are you suggesting to just let the battery run down (in those short situations) and fill back up via the comp/ICE...?
  6. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Turn off the A/C, turn off headlights, etc.
  7. 2clicker
    2clicker Member
    114
    28
    St. Louis
    ahhh i see. thanks!
  8. JimboPalmer
    12,470
    6,867
    Greenwood MS USA
    By the way, the battery DOES fill up if you drive down a steep hill over 600 feet tall. At that point you lose the regenerative braking. (which is why the battery tries not to fill up)
    2clicker likes this.
