Touch Controls on steering wheel seem to be melting
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by LeeCincy, Sep 1, 2020.
  1. LeeCincy
    LeeCincy Junior Member
    Ohio
    2013 Prius Plug-in
    When I purchased my 2013 PIP I noticed what looked like a sticky residue on the left controls as pictured here. I tried to wipe it off with some cleanser but the problem persisted. In fact, it started to "spread" left and is now starting to show on the volume up and down buttons (at first it was just the track skip buttons that were affected). Has anyone else experienced this? Thanks!
  2. Mendel Leisk
    38,664
    There were similar reports, regarding the 2nd gen hatch release, the rubber coming apart. Maybe the same material.
    49,401
    mine are in perfect condition, and i don't recall anyone mentioning it. hopefully, they are easy to replace.
    maybe the car was from a warm climate and parked in the sun all day
  4. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    Never heard of that happening on the steering wheel controls. I wonder if the PO got some kind of solvent on them. Perhaps a cleaning gone bad? I have never investigated replacing those buttons. They are in the airbag area, so you'll want to take precautions.
    Here's a video on taking it apart. The poor guy doesn't know there's no such word as "unloosen." Also, I would disconnect the airbag and get it out of the way.
  5. bisco
    49,401
    with any luck, they just pry out and new ones work in around the edges
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,158
    2,207
    Taylors, SC
    It happens a lot with the radio and other knobs on Porsches and other expensive German and Italian cars.
    The molecules that make up the rubber is secured by covalent bonds that hold the rubber strands or "strings" together. In rubber, sulfur is used to bond the strands together in a cage like structure. The process, first discovered by Charles Goodyear, is called vulcanization.
    When deformed, the strands bend and return to their previous state.
    According to the Kinetic Molecular Theory (KMT) the molecules and in constant vibrating motion. When the vibration breaks the bonds, rubber becomes mushy. Age combined with higher temperatures quicken this deterioration.
    The only solution is replacement of the rubber part.
  7. Mendel Leisk
    38,664
    2nd gen discussion postulated it could something like sunscreen reacting with the rubber.
    Yeah hopefully. OP could check part numbers here:
    Toyota Parts and Accessories - Official Online Store
    (click on "Hybrid and FCV" first, get's you started)
    jerrymildred likes this.
  8. jerrymildred
    11,508
    14,109
    Tampa, FL
    OK, I guess not everyone watched the video. The connector is on the back of the button housing. You have to take the whole housing out to release the clip on the connector.
  9. bisco
    49,401
    bummer :unsure:
  10. jerrymildred
    11,508
    14,109
    Tampa, FL
    Minor bummer. I had the steering wheel off my wife's Gen 2 and it was very easy to do. The Gen 3 looks very similar.
