touch up paint for interior (because I'm an idiot)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pan2, May 25, 2019.
  1. pan2
    pan2 Junior Member
    San Jose, CA
    I accidentally cracked a plastic pieces on the top of the dashboard in my 2008 Prius. I did a sloppy job gluing it back in place (mistake number one: it was dark out and my lighting wasn't good) and some glue seeped out of the seam where the pieces met. No problem I thought --- I'll just use some nail polish remover to clean up that excess glue. I'm sure you can guess mistake number two: apparently nail polish remover is not good for colored plastic. So now it looks much worse and the grey metallic plastic has a big beige discolored area (see attached photo).
    I'm wondering if there's an inexpensive way to make this look better. It doesn't need to be perfect. I'm about to sell the car and it's old anyway, but any easy fixup would be welcomed. Thanks for saving me from my stupidity!
  2. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    I would just go to an LQK junk yard and pull the interior pieces you need. Painting will stick out no matter what.
    OR, sell at a slight discount reflecting the cost of those interior pieces at LQK.
  3. Mendel Leisk
    40,586
    Remove the effective pieces (and maybe any adjacent that would otherwise clash) and spray with mat-black plasti-dip?
    Here's a burnished shifter bezel I re-did a while back:
    Before:
    After:
    Installed:
    Raytheeagle likes this.
  4. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Or just get an inexpensive dash cover and hide it.
  5. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    Junkyard is a good bet.
    Otherwise pop it out and spraypaint it. Paints meant for plastic model kits work well. Testors makes lots of semi-metallic finishes, shouldn't be hard to match.
  6. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    Ebay. These items are low demand so prices should be low. Most sellers are usually junk yard dealers so find one that A) has a low price and B) accepts offers.
    GOOD LUCK!
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    For future reference:
    Nail polish is basically PAINT.
    Nail polish remover removes all kinds of paint.
    Find a cute "sticker" to put over it.
  8. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
  9. Kenny94945
    Kenny94945 Active Member
    843
    418
    Sausalito
    2016 Prius v wagon
    Ouch....
    Cheapest is probably to remove all the damaged pieces and any piece that mirrors it (to keep artistic symmetry) sand, prime and spray repaint.
    …. Murphy's Law at work.
    Good luck.
  10. Mendel Leisk
    40,586
    Maybe don't sand? The pieces might have a texture, and sanding would disrupt it. Make sure the pieces are really clean though, say isopropyl alcohol on an old toothbrush.
    Addendum: they do look pretty smooth though, meh.
  11. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    I've only done this a couple of times, I find that sanding the parts is the right move. New paint adheres better if the base surface has a little bit of roughness, and the overall finish is more even if all of it has been sanded the same way.
    Some paint will provide its own texture, and the method of application will affect the final texture too.
    Fine grit, 800-2000 is usually about right.
