Touchscreen replacement sticker shock
Discussion in 'Newbie Forum' started by rebec, Apr 16, 2010.
  1. rebec
    rebec New Member
    Sacramento, CA
    I'm new to the forum and hoping someone out there has an answer. My 2006 Prius' touchscreen has stopped working...Only way to get info is to use the on-steering-wheel controls. The Toyota dealer (Roseville, CA) said it needs to be replaced and it will cost $1800! That's like buying a new imac. Is there anyother way to get this repaired? Help! I've loved my Prius (which I got second hand last year) but if this is the repair costs attached I might as well trade in for a Ford hybrid. Any advice would be appreciated.
  2. linuxpenguin
    linuxpenguin Active Member
    352
    182
    I replied to your other post on the Gen2 forum.
    Andrew
  3. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Used MFDs are often available on eBay for about $800 and installation takes about 45 minutes. Make certain that the one you consider is from a 2006-2008 Prius (The 2004-2005 MFD will not work) and had the same options that you had on your Prius.
    JeffD
  4. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
  5. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Shouldn't happen on an '06, though; there may be something
    else wrong. But hey, if the symptoms match...
    _H*
