touring centercaps, ?wrong ones
Discussion in 'Gen 2 Prius Accessories & Modifications' started by turboboy, Oct 14, 2008.
  1. turboboy
    turboboy New Member
    29
    upstate ny
    ordered center caps for 08 touring rims from a site advertiser, from previous posts i ordered the caps that fit on the 15 inch rims, they fit fine but have open slots that alternate around the rim of the caps ,they look fine from straight on but if you look closely from the side you can see the open slots. are these the wrong ones for the prius touring rims ? thanks john
  2. KAR IDEA
    KAR IDEA Member
    465
    Lake Peekskill, NY USA
    Three Touring
    I'm assuming you have a touring, and you removed the wheel covers, then ordered and put on the center caps to cover up the hole in the middle? If this is so, and the center caps sit in the holes tightly, then you ordered the right ones. They are the same center caps that are used on the non-touring Prius editions , and the Toyota Camry.
    Dave
