Touring with 15 inch wheels
Discussion in 'Gen 2 Prius Main Forum' started by Joe13, Apr 19, 2009.
  1. Joe13
    Joe13 Junior Member
    Norman, Oklahoma
    Thirteen days ago I brought home my new "09 Prius Touring. I just noticed today that it has the 6 spoke 15 inch wheels instead of the 7 spoke 16 inch wheels that Toyota.com says are standard on this car. So, I have a couple of questions. Can I go back to my dealer and ask for the 16 inchers or do some Tourings come with 15 inch wheels and that's just the way it is? Also, do I even want 16 inch wheels? Am I getting better mpg with the smaller ones? I do think the 7 spoke wheels look better.
  2. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    According to my 08 brochure, Touring's come with 195/55R16 tires and 16" rims.
    Something seems wrong there.
  3. msirach
    msirach Member
    321
    Southern Illinois
    I would check with the dealer. 185/65/15 is 76.9" diameter and 195/55/16 is 76.8" diameter so the 15" tire is .1 mph too slow.
    We have an 08 and I know of several more and they all have the 16". The 09 specs at Toyota.com only show 16's on Touring. I bet someone associated with the dealer liked 16's and wanted them.
    I would definitely question the dealer.
  4. Patrick Wong
    18,210
    6,511
    If your car has 15" wheels, is it possible that this is the standard Prius model and not the Touring model? All Touring models should have the 16" wheels. What does the Toyota window sticker say about the model and type of wheels installed?
    You should get better mpg with the 15" tires because those are slightly narrower compared to the 16" tires.
    Does your car have the big Touring spoiler, or the shorter spoiler that standard Prius comes with?
  5. msirach
    msirach Member
    321
    Southern Illinois
    If they sold me a Prius for a touring price, I might talk to more than the dealer. Check your spare tire and see if it is a 15" or a 16" I'm not sure if there is a difference in the spare though. I can't check the spare in ours since it's about 750 miles away in VA. Does the window sticker and or receipt say "Touring"?
  6. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    Hello Joe:
    I just bought an '09 standard, and I have the '09 brochure on hand. I just checked, and the '09 Touring only comes with 16", 7 spoke alloy wheels and P195/55R16 tires.
    You need to get thee back to the dealer, and find out what kind of trickery is going on.
    Please let us know what happens.
    Best wishes,
  7. exbauer
    exbauer Active Member
    1,188
    102
    Washington
    I would definitely go back to the dealer if you had agreed to buy a touring. It sounds like they sold you a base pkg 6. Let us know the outcome.
  8. liverbomb88
    liverbomb88 Push the Button!
    130
    16
    In a galaxy far far away...
    What does your window sticker say, is your rear spoiler bigger, and have you matched up the VINs?
  9. patsparks
    10,664
    567
    Adelaide South Australia
    Something is rotten in Denmark (Or Oklahoma) As others said check the spoiler and contact Toyota and ask what you have. You will need to tell them the VIN number. Then ring your lawyer and the police. If it isn't a touring model but you paid for a touring model they deserve to go to gaol. (jail)
    Maybe the wrong wheels managed to find the wrong car in the factory?
    Spare tyres are all the same.
  10. msirach
    msirach Member
    321
    Southern Illinois
    I just measured the spoiler on the standard Prius and if you measure on top from the window back it is 6.5". I think the Touring spoiler is about 2" longer.
  11. Joe13
    Joe13 Junior Member
    Norman, Oklahoma
    Ok, so here's what happened. Two weeks ago I got inspired to buy a Prius. I went to the dealership, told them I wanted a new 09 and I wanted it "loaded." They showed me a car, package 6, I liked it, I bought it. I came home, went online, to find out more about it. Isn't that stupid, to do my research after instead of before buying the car. On Toyota.com it shows two types: hatchback and sedan (touring.) Now, my car didn't have a window sticker (?) but on the purchase agreement it says "sedan." That's why I thought it was a touring. Well, guess what, IT'S NOT. Apart from some embarrassment, I'm quite happy with my new little base Prius. And I'm happy that I don't have a reason to be suspicious of my dealership just yet, only of my impetuous car buying technique.
  12. Patrick Wong
    18,210
    6,511
    Thanks for the update.
    Since your car contains package 6 options I would not call it a "base" model. Base refers to a vehicle with no option packages. I would call your car a standard Prius with option pkg 6.
    I suggest you change your vehicle "package" in your profile to not indicate Touring, and I hope you enjoy driving your new car!
  13. Qlara
    Qlara New Member
    488
    Your dealer still owes you the Window Sticker then.
    The WS always comes with the new car selling, and the Prius Touring only comes with 16" wheels.
  14. yardman 49
    606
    77
    Northern Kentucky
    Hello Joe:
    I also think that it is required by law that a new car have the windown sticker on it.
    Sometimes, when you buy a new vehicle, the dealer will remove it when doing the final "detailing" prior to you picking up the car. If so, they will usually place it in the glove box. You should hold on to it for your records.
    You will know if you have the correct window sticker, as your car's VIN will be on the sticker.
    When on display in the lot or showroom (prior to your purchase), the sticker should have been affixed to a side window.
    Best wishes,
  15. Joe13
    Joe13 Junior Member
    Norman, Oklahoma
    Thanks everybody for the help and advice. I called my sales guy and he says the sticker is long gone. Kind of a mystery to me. But I'm not going to make a big deal about it. He says he can get me a print-out with all the info that's on the sticker. OK, that's good enough since evidently it's all I'm going to get. I'm too happy with the car to be unhappy about that.
  16. yardman 49
    606
    77
    Northern Kentucky
    Hello Joe:
    As long as he can make you a printout with all the original information, that should be good.
    I'm assuming that this was a "brand new" car, and not a used one? If new, the mileage should of course be very low, maybe only from a few test drives, or from the dealer having the car driven over from another dealership.
    Enjoy your new Prius! I also have an '09, and am really enjoying it!
    Best wishes,
