towed a trailer 1200 mi, 52mpg!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by isibrigade, Feb 28, 2010.
  1. isibrigade
    isibrigade Junior Member
    San Diego
    SAN DIEGO to MENDECINO, CA and back.
    Curt hitch.
    I built this custom trailer for the tandem and some camping gear. Modified a Build-it-yourself in-the-box trailer I bought off ebay to extend the tongue and allow more room for the tandem. I took a yakima rack and extended it to mount the bike. Only used it once so far, but everything stayed on.
    With all the camping gear and tandem bike loaded, I doubt the rig weighed more than 350lbs.
    Stopped in monteray bay for this quick pic. Fun times.
    just over 52mpg, about 1,200 miles round-trip.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Multiple postings confuse and clutter the forums. Try to pick the best thread and post there. If you absolutely must post in more than one thread, use a link rather than duplicating the entire post.
    Tom
  3. PRIUS007
    PRIUS007 James Bond -007
    133
    Mundelein, Illinois
    Not bad mileage towing there.
    I don't really know as well if this belongs in the 'Modifications' section.
  4. isibrigade
    San Diego
    I did mention the fact that I installed a Curt . . .and designed/built a custom trailer just for the prius. . .but I don't know, maybe it belongs somewhere else.:confused:
  5. isibrigade
    San Diego
    The only thing cluttering this forum is unnecessary posts like these.
    I know that people like you might get confused when reading a duplicate post, which is why I mentioned it was a duplicate post in the other section. I also went on to explain why I posted in both sections as it is relevant to both. For your sake, next time I will post a link though.
    Joeman200 and triumph1 like this.
  6. mikeysaid
    mikeysaid Junior Member
    44
    Phoenix, Arizona
    52mpg over 1200 miles WITH A TRAILER??? what is your secret? you always go 55? how'd you do it?
  7. isibrigade
    San Diego
    By CA law, speed limit = 55mph while towing anyways. I will say that there were some stretches of the HWY 5 that I was doing well over 65 when searching for bathrooms for the kids.:D
  8. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    Nice work on the trailer, and great mpg! Congrats, and thanks for sharing.
    Got any pics or guidance about the wiring on the car?
    What was the kit called, and what do they sell for?
  9. isibrigade
    San Diego
    Wiring info I took from Darells page "Prius Trailer Wiring (Plug 'n' Play)" http://www.evnut.com/
    Followed the instructions and things went well. (outside of pulling the wires from the harness)
    Trailer Kit purchased on ebay was one of these:
    Brand New Utility Trailer 860 lb load Motorcycle ATV * : eBay Motors (item 320495123386 end time Mar-07-10 19:00:45 PST)
    I was insipired by Darells Sportsrig, but very unwilling to drop $1300 on a trailer. This $150 deal on Ebay fit my pocketbook a little better.
    After assembling the kit, I made some modifications. I added a stainless flatbed platform. Just used a leftover 1/16" sheet from a project with leftovers. I had it sheared to the dimensions I needed.
    I also machined an extension for the tongue to allow for more room for the tandem. This also makes it much eaiser to drive with. The longer the tongue, the less 'sensitive' the trailer will be when backing into a parking spot or driveway.
    The Yakima rack you see was cut in half. I made an extension to allow for the tandem and it was mounted with some bolts to the trailer.
    3 people like this.
  10. owenxguo
    owenxguo New Member
    SF Bay Area
    wow that's great MPG
  11. jdenenberg
    jdenenberg EE Professor
    3,831
    1,824
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You should plan on doing an early Transmission fluid (Toyota type WS) refresh as your HSD is working harder than normal when loaded with even a light trailer. The interval suggested by lab testing ATF in a Gen2 Prius is 60k miles. Do your first exchange at 30k miles and send in a sample (use a clean poly bottle - about 2 oz) for testing (about $100 for new ATF at a dealer, $25 for lab testing at R&G Laboratories, Inc or PdMA Corporation - Oil Analysis - Excellence in Lubricant Analysis with viscosity index) and report the results here.
    JeffD
  12. isibrigade
    San Diego
    Maybe something I'll look into. . .
    Would you expect me to find something foul? I can imagine a difference if I did this on a regular basis, but this haul doesn't even represent 5% of the cars total lifespan in milage.
    I would say that the daily wear and tear from the way my wife drives would exceed that of towing our trailer anyways.
    HER MPG = 38
    MY MPG = 56 :D
  13. speakchucker
    speakchucker Junior Member
    bozeman
    Isi, can you tell me what bike rack you're using there? I'd love one!
  14. imOCD4a_prius
    imOCD4a_prius Member
    144
    the TREASURE COAST OF Florida
    I need information about towing a ''mini-trailer' @ approx. 750lbs.
    Thank you in advance
  15. ETC(SS)
    6,483
    Interesting strategery, resurrecting an almost 9-year-old post!
    :p
    Executive Summary:
    1. Use the Googles to find a receiver....such as....
    Reese Towpower Hitch Class III, 2" Box Opening, Model #51195 - Walmart.com
    2. Source a small trailer at one of the big-box stores.....
    https://www.lowes.com/pd/Carry-On-Trailer-5-ft-x-8-ft-Wire-Mesh-Utility-Trailer-with-Ramp-Gate/3005264?cm_mmc=SCE_BINGPLA_ONLY-_-ToolsAndHardware-_-TrailersRampsAndTowing-_-3005264:Carry-On_Trailer&CAWELAID=&kpid=3005264&CAGPSPN=pla{ifdyn:dyn}&k_clickID=900e25a2-46fd-4789-903f-d898de735bcb&msclkid=f794ffd8737c16a275cea415801a0edc
    A 5x8' wire mesh trailer will be about 350#, and even a 12-year-old Prius should be able to tow light loads on this trailer relatively short distances.
    3. Lights:
    You live in Florida.
    Nobody I've seen there uses trailer lights.
    There should be instructions with the receiver kit in case you plan to travel out of state.
    BE CAREFUL if you tow long distances or at interstate speeds!
    Pulling a load is easy-peasy....
    It's the turning and stopping that always messes people up!
    4. Registration/Tags:
    See #3: Lights.
    5. With your towing parameters you should not have to get into load leveling or electric brakes.
    Priuses have something like an 800# cargo budget - pax included.
    Don't tow stupid and you won't get into trouble.
    Good Luck!
  16. imOCD4a_prius
    144
    Thanks for the quick reply. I now have a bit more info of the trailer my son is GIVING us...it's a "
    SignaTour Campers Teardrop Trailer
    approx 860# (oh oh ?)
    it's name: "Tote 5+" 5 X 8
    Hope the info helps you & others help me out. I'd NEVER tow anything w/o lights. Growing 'up north' in Ct. taught me better. :)
    PS My son just reminded me he towed this , fully packed w/ a/c w/ his Fiat. B-4 he got his truck & a larger camper for his family. So, if an Italian 4Cyl, made by my pisons can tow it-you'd think a PRIUS should ? !
  17. arjanmeijerman
    arjanmeijerman Junior Member
    NL
    Business Edition
    Are you allowed to tow a trailer behind a prius of that generation?
    Here in Europe you are committing a felony when towing any trailer behind a prius since it is not certified for towing..
    Verstuurd vanaf mijn LG-M700 met Tapatalk
