towing a prius v
Discussion in 'Prius v Technical Discussion' started by Topdog66, May 8, 2019.
  1. Topdog66
    Topdog66 New Member
    Portage WI
    I will be relocating to Harlingen Texas soon and will be traveling approximately 1500 miles. I have been hard pressed to get any solid answer to my question as to whether or not I can tow my Prius V on a tow dolly without any problems. Any help would be appreciated. Thanks.
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,481
    6,570
    Texas Hill Country
    Towing with the front wheels up will be fine.
    Tim Jones likes this.
  3. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    FWIW we spend our winters at South Padre Island just to the SE of Harlingen. Enjoy the weather particularly over the winter...
  4. Tommar
    Tommar New Member
    Waco, TX
    Three Touring
    So I have a 2016 PRIUS that I wish to tow on a dolly. Some dolly's require that the steering be locked and some do not. Does my Prius' steering lock? Also what diameter tires do prius' have?
  5. Air_Boss
    Air_Boss Senior Member
    4,220
    1,188
    New Yawk
    Yes, the steering locks (a regulatory mandate). Wheel/tire size depends on model/trim. Look at the tire sidewall for diameter, for example, the trailing "15" in this size 205/60R15 designates a 15" diameter wheel. Tire diameter can be measured directly, or using the tire manufacturers specs for the model and size as above.
