towing wire harness
Discussion in 'Prius c Accessories and Modifications' started by tgpii, May 18, 2014.
  1. tgpii
    tgpii Member
    382
    63
    Tapier Lake/Orland Park, Ilinois
    I know I have ask this in the past and it has been asked by others. However I am going to ask. Do they have a plug and play towing wire harness for the Prius C, not the Prius but Prius c?
  2. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    i havent seen any plug and play models. i have seen models that you simply splice into te run, brake and turn signals and it converts into the trailer harness.
    mertechperformance likes this.
  3. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    There will not be a "plug n play" harness. Might be a "tap in n play" setup. Got to tap into the existing wires so you will then have "plug n play". It will be a simple install when you know where to put the taps. I have not done the C yet. Did my Vibe. Took about 10 minutes and I had to use the kit with box for extra wire. Got it at Autozone. I got the wiring diagram from the Vibe forum. Maybe someone can direct you to the diagram for the C. It will be pretty simple.
    You might check the kits at the parts store and find a diagram for the C.
    Dan
  4. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    May I ask why you need to tow your c around often?
  5. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    I'm assuming they're going to use their C TO tow, not GET towed? correct us both , as one of us must be wrong, ha ha. It'll tow about 1,000 even though Toyota recommends zero.
  6. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    Toyota only recommends 0 because you can't recommend a negative number.
  7. mertechperformance
    532
    126
    Nor-caL
    Yet a LESS powerful car on the same platform can tow 1,000lbs... Yaris has been on again, off again tow capable, the Echo could tow 1,000...
    The same argument was had with SCION xA/xB years ago.
  8. tgpii
    tgpii Member
    382
    63
    For the Prius but not the Prius C. For Prius C you have to splice the wires.
  9. tgpii
    tgpii Member
    382
    63
    For the Prius but not the Prius C. For Prius C you have to splice the wires. Isn't tap in play and plug in play same thing? This is so I can tow a very small trailer. Not to be towed. :LOL:
  10. mertechperformance
    532
    126
    Nor-caL
    Plug and play is very different than a tap or splice in harness.
    SGH-T889 ?
  11. xliderider
    xliderider Senior Member
    7,891
    3,125
    Honolulu, HI
    No, they are different. Plug and play means no wire cutting or splicing is required. All connections would be made with an adapter, which would plug into an existing wiring harness connector.
    SCH-I535
  12. mahout
    mahout Active Member
    655
    116
    NC
    My guess is they're towing it behind an RV. Hope they use a tow dolly and then of course besides more safe thee dolly has the wiring to connect to the RV brake and tail lights.. If the C is used to tow a bike trilaer again only the brake lights and tail lights need to be tappee into the C wires; pretty easy just make sure the disconnect is not at the wire taps.
    There is no plug and play in the electronic sense. Just connect, test, and be off.
  13. tgpii
    tgpii Member
    382
    63
    Not tow the C, but use the C for towing! LOL
  14. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    I was afraid of that, not a good idea at all. short wheelbase vehicles are very bad at towing.
  15. priusCpilot
    priusCpilot Active Member
    631
    209
    LA
    Curt makes a PiP harness now for the harness plug.
    I love towing with my C. I tow my Jetski with it no problems.
  16. mertechperformance
    532
    126
    Nor-caL
    100.4" isn't too short of a wheelbase let alone for a compact/sub compact vehicle.
    For reference a long bed pickup with four doors will have a wheelbase around 160"
    A SCION iQ is 79"
    Lots of variables. just saying 100 isn;t terrible. a highlander can tow 5,000 and only has a 109.8" wheelbase...
