Towing With a Prime?
Discussion in 'Prime Main Forum (2017-2022)' started by bensmiata, Jun 6, 2018.
  1. bensmiata
    bensmiata Member
    55
    39
    DC
  2. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    No, but I did haul 4 - 2x4x10's and then went back and hauled 2 - 2x4x16' boards. My son had my Tundra. I was bummed. Used about 6 towels to protect the interior!
  3. Trollbait
    11,514
    There is a thread here about the empty space under the traction battery, and how to get to it. That could be a wire route.
    Here's the thread
    I found the missing 4" (vertical) in the trunk. It is below the battery. | PriusChat
    #3 Trollbait, Jun 7, 2018
  4. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    BTW user manual says not to tow. You'd lose ur warrenty
  5. Trollbait
    11,514
    It may not even have a tow rating in Europe.
    The Prius does; 750kg.
  6. Simbaboy
    Simbaboy Active Member
    130
    112
    Mid-Michigan
    I am easily towing a small Harbor Freight trailer (300 pound Yamaha TW200 dual sport motorcycle). I also have a roof rack and roof carrier. This is with a 2009 G2 Prius.
    It would be disappointing, if you can't with your 2017. I thought the newer Prii were rated to tow OFFICIALLY.
    Simba
    Worldbuyer likes this.
  7. Trollbait
    11,514
    The official tow rating for the Prius is still 0. It has a 750kg rating in Europe and elsewhere. The reason for the difference is in the trailer regulations. US ones transfer more of the trailer's weight onto the car and its frame. Europe calls for trailer brakes at lower weights, and the weight distribution they use on a trailer makes them less stable at highway speeds.
    The Prius finally got a to rating because Toyota finally installed a cooler for the overworked automatic transmission fluid they use in the hybrid transaxle.
    The Prime is heavier than the Prius, with most of that extra weight in the back. It doesn't have a tow rating at all.
