Towing with the 2004-5 Prius
Discussion in 'Gen 2 Prius Main Forum' started by froggdancer, Oct 27, 2004.
  1. froggdancer
    froggdancer New Member
    Pasadena, California
    Basically, I'm trying to find people who have used their Prius to tow things. Here's why:
    I recently became enamored with Teardrop trailers which are small trailers (usually just a bed inside and a kitchen in the back) from 650-1500 lbs. I've seen pictures of VW bugs pulling these things! For a few websites to describe, see:
    http://www.cozycruiser.com/cozycruiser_deluxe.html
    http://www.digisys.net/edevold/index.htm
    The problem is, I figured out that I dearly want one of these things a few months AFTER I bought the Prius (which I also quite love).
    So, I know it is not recommended to tow with the Prius... but I was wondering if anyone has and how much weight they have pulled and what it did to the car.
    I'd be much obliged for any info either posted here or sent to my personal email!
    KS
    [email protected]
  2. SecretSquirrel
    SecretSquirrel New Member
    I wouldn't try it - the owners manual says the load is something like 837 lbs (including passengers). Not much room for towing! Also, I recall from the manual that towing is just not recommended.
  3. Frank Hudon
    Frank Hudon Senior Member
    4,147
    do a search on towing it's been beaten to death here on PC
  4. froggdancer
    I had done a search for "tow" and "weight" and "capacity" and I did find http://www.coastaletech.com/
    ...but most of the hits were for people who had problems with the car and needed to get the car towed, not for using the car to tow something else. I guess I just got bogged down and decided to post the question anew.
    Plus, I really wanted to find out, specifically, if anyone had towed a Teardrop trailer so I thought this post might draw some Teardrop specific responses (when I did a search, there was nothing on Teardrop trailers).
  5. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Why don't you check with Toyota at their customer care toll free number.
  6. naterprius
    naterprius Senior Member
    1,843
    froggdancer, the short answer: No, the Prius cannot tow a trailer.
    The long answer: It might be possible, but no one is certain how well the car will perform or what the short term effects (Poor braking, overheating, etc) or long term effects (increased wear and tear) of towing a trailer might be. Toyota certainly will not warranty repairs caused by towing a load that is too heavy.
    I think you will have a hard time finding anyone who is willing to tow a trailer with their Prius.
    As with anyone who is venturing out into something unknown, if you do decide to try it, let us know how it goes.
    Nate
  7. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    I'm pretty sure they will say "don't" since the manual says it is not recommended. The dealer can't really say "go ahead". I think you are looking at way too much weight. How about trailers made to be pulled by motorcycles instead. There are some that make little sleepers :)
  8. daniel
    14,487
    1,518
    Spokane, WA
    The trailer you are describing sounds so minimal (in terms of comfort) that it probably wouldn't be all that much of a step down to get a big tent, a good air mattress (the best ones are quite comfortable) and a camp stove.
  9. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Has anyone adapted a trailer harness of some sort to provide brake and turn signals to their trailer/bike rack. I would think that some states would require the use of these lights when obstructing the Prius lights. Some states even require a license plate bracket, with illumination, on the back if the plate on the car is obstructed.
  10. FireEngineer
    1,247
    124
    Could the reason Toyota does not want the Prius to tow have less to do with the hybrid system itself and more with the CVT transmission? I am not aware of any vehicle which has a CVT which permits towing. Also, seeing pictures of the CVT used in the Prius, overheating might be a concern as well as excess stress on the belt.
  11. IsrAmeriPrius
    4,333
    Southern California
    The Prius transmission does not use a belt. It is a planetary gear system.
  12. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i dont feel that the Prius has the torque to tow anything of any weight.
    many look at the ample torque of the EV as being capable but that cannot be used as a basis for towing since heavy or extreme use of the vehicle (steep hills OR towing) will drain the traction battery and all but take the EV out of the system leaving only the ICE to power the car.
    the Motortrend Car of the Year article details this on their test drive when they basically ran the traction battery down as far as they could then floored it going up a steep very long hill. the power of the car was greatly reduced without the benefit of the EV assist.
    so towing a trailer even on level ground will cause the EV to kick in more often than normally which in turn will make charging the traction battery take much longer to the point that any slope may prove to be disasterous.
    MT reported doing only 35 mph at the top of their test grade with a drained (well drained as far as the computer would let it be drained) traction battery offering no help.
  13. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    CORRECTION
    the article mentioned in my previous post was from Consumers Report... sorry about that.
    they also mentioned that with a fully charged traction battery, the car flew up the hill "easily maintaining a speed of 75 mph"
  14. Frank Hudon
    4,147
    The Prius uses a hi-volume drive chain in the link from the PSD to the intermediate reduction gear in the drive unit. The function of the intermediate reduction gear is to reverse the direction of the power flow from the drive motors and ICE to the forward direction required to make the car go forward without the need for a reverse rotation camshaft in the ICE. This is a common feature of almost all FWD cars, as the ICE rotates CW when viewed from the front end, and if there is no intermediate gear the diffy turns opposite. Is the Hi-vol chain a weak point, short answer is No. If a taxi operation can put over 330,000KM on the drive unit without problems I doubt that towing a trailer for reasonable distances is either. Taxi operation is probably the most demanding on tranny's and diffy's there is, lots of heavy loads, IE. near maximum gross vehicle weight. In the Prius, MG1 is the main provider of motive power to operate the car, with the HV battery supplementing with additional power as required and determined by the computers. The MG's 1+2 both have thermistors buried in the windings that provide ongoing readouts for the computers to look and evaluate to determine the operation of the drive unit. Along with temp sensors in the battery and the air ducting for it. This car is a lot better at determining what if anything is wrong with any parameter than us mortals, and will shut it down if anything goes wildly out of the norm. I've used both the Classic and the 2k4 in the mountains and never had a problem with either, the Classic is a bit better in long continuous climbs than the 2k4 in my opinion and that is totally subjective but both have never had a problem as any of you who have crossed the Cascades will attest to. Now to towing a small trailer that is under the maximum gross vehicle weight as being a major problem, in my opinion, no.
  15. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i went up to Mt. Saint Helens viewpoint a vertical rise of 6000 feet at 65 mph and never had a problem, that includes a 75 mph pass of a slow moving vehicle on a two lane road going uphill.
    i was impressed.
  16. Craig0812
    Craig0812 New Member
    36
    Houston TX
    Unfortunately, this vehicles wasn't designed to tow, but I am sure you can haul bicycles on either the top or install a hitch for hauling on the rear. Anyone install a bike rack on top? Please advise....
  17. Frank Hudon
    4,147
    3 bikes on a roof top mount has way more drag than a small trailer has. By a country mile, same goes for cross mount on the back of the car. The trailer I tow is completely hidden in the slip stream of the car. I can't see it in any mirror on the car. I've seen people hauling Zodiac boats and tent trailers with the Prius and non seem any worse for it. The reason Toyota doesn't recommend towing is you can bet some goof will hook up a 22 foot travel trailer to it and then head out thru the Rocky Mountains. Read my comment on CGVW and understand the Prius can carry about 800 lbs. all in, fuel, passengers and driver If you have a driver at 175Lbs and 60Lbs of fuel, that leaves what 560 lbs for luggage,rocks, what ever. If your trailer weighs 400Lbs loaded and your trailer hitch weighs 70Lbs it leaves you 95Lbs for beer and pretzels. And don't drink and drive.
  18. Batavier
    Batavier Member
    442
    The Netherlands
    And don't choke on the Pretzels... :)
  19. plusaf
    plusaf plusaf
    324
    Raleigh, NC
    yeah, where do i hook the trailer connection???
    and as for long-term trailering, i'll be letting all y'all know this summer... i'm assembling the trailer now..
    http://www.plusaf.com/prius/prius.htm
