Toyota’s new Prius model to get record 40 km per liter
Discussion in 'Gen 4 Prius Main Forum' started by Tideland Prius, Jan 20, 2015.
  1. Tideland Prius
    16,125
    Obviously we can't just use 40km/L (94mpg US) so if we do simple maths...
    40km/L = 2.5L/100km
    32.6km/L = 3.0L/100km.
    1/[2.5/3.0] = 1.227x improvement
    50mpg combined x 1.2 = 61mpg.
    Just strictly using the incremental improvement, that's how I inferred the mpg equivalent. Does that sound like a reasonable guess? Or have I simplified the math too much?
    miscrms, fuzzy1 and jw_teacher like this.
  2. jw_teacher
    jw_teacher Junior Member
    87
    MO
    2018 Prius Prime
    It sounds reasonable. With the competition closing the gap, Toyota desperately needed to boost the Prius' MPG by a good margin anyway. I would be thrilled if the new Prius got 61 MPG.
  3. ETC(SS)
    6,542
    *Sigh!*
    I just wish they could get the styling right....
    [​IMG][​IMG]
  4. walter592
    walter592 Junior Member
    36
    I think the current model prius is rated at 36km/L in Japan...
  5. Mendel Leisk
    38,646
    So 10% improvement. Still good...
  6. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Why do you think that a simple conversion is NOT sufficient ??
    I don't understand what your math is really trying to accomplish.
    Certainly not obvioius to me.
  7. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Mileage quotes out of Japan are typically based on their test cycle which is wildly optimistic. The current Prius is rated like 72mpg or somesuch on it so, I think, Tideland is trying to factor that into a US figure.
    Tideland Prius likes this.
  8. Easy Rider 2
    1,584
    257
    Ocala, FL
    Check. Thank you.
  9. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    Math like that doesn't work with US cycle.
    Prius c (Aqua) was rated 37km/l there yet 50 MPG here.
    We'll have to see how well it does in more aggressive cycle and higher speed.
  10. bisco
    49,373
    sounds like good news...
  11. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    The Gen3's rating is ~10% higher than the revised Gen2 rating. Still haven't seen it. Another 10% increase would put the Gen4 at 55mpg.
  12. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    The Aqua is rated as 35.4km/L or 83 mpg but gets 50 here. If you scale that against the reported 40km/L or 94 mpg it works out to 57 mpg.
    If you scale the Liftback JC08 vs EPA and scale the new 94 mph result it is 61 mpg.
    I'm amazed if this result is actually confirmed. It would be just a fraction better than a 20% improvement over already excellent numbers.
    I'm a little skeptical at this point. It seems too good to be true.
  13. Tideland Prius
    16,125
    @Jeff N, even at 57, that's better than the "10% improvement" reports.
  14. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Or maybe this newspaper report is confused and the new 94 mpg number is based on the old Japanese 10-15 test on which the old Liftback gets about 38/L or 89 mpg. That would be a 5-6% improvement.
  15. iplug
    iplug Senior Member
    2,455
    1,703
    Rocklin, CA
    from the article: "resin materials used as much as possible to downsize and lighten the weight of the fuel cell"
    Fuel cell??? Guessing that is a translation mistake, but not sure what was meant. Any ideas?
  16. GregP507
    GregP507 Senior Member
    3,002
    480
    I think this is the road to the winning strategy. Taking a technological lead is what made the Prius the most successful hybrid on the market.
  17. neez
    neez Member
    194
    37
    I'll take the same fuel economy it gets now, as long as they add AWD. That's what i want here in the states because there are no other competitors with great fuel economy and AWD here in the U.S. The only diesel awd's are all suv's, and none of the diesels VW offers have awd.
    jdenenberg likes this.
  18. inferno
    inferno Senior Member
    1,072
    405
    I read the line market it in the fall.
    Ok...so the reveal we be before then right? Usually a marketing strategy in the fall will involve sales then or right after. IE - why would you market something you can't by?
  19. Tideland Prius
    16,125
    Good point. It also says the Prius weighs 1,600kg. It doesn't.
    Something's fishy.
  20. bisco
    49,373
