Toyota Annouces Towing Package for 2016 Prius
Discussion in 'Gen 4 Prius Accessories and Modifications' started by William Redoubt, Apr 21, 2016.
Tags:
  1. William Redoubt
    William Redoubt Senior Member
    1,215
    1,165
    Coronado Island, California
    Just a few hours ago this popped up on the Interwebs. Toyota announced its Prius towing package. That's the good news. The bad news, apparently is that it is for UK models only. Not for US.
    49,693
    agreed, bad news.
  3. dpbsmith4
    dpbsmith4 Junior Member
    51
    22
    New England
    Four Touring
    Curious: how would you tow anything without a) blocking the rear view camera, and b) getting a constant alert from the proximity sensors at the back?
  4. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    If there is a towing package, there will probably be an update to Entune that will allow the car to be in towing mode so the sensors don't go off. Just a guess...
    #4 'LectroFuel, Apr 21, 2016
  5. bisco
    49,693
    and a remote camera to velcro onto the back of the trailer.
    RCO likes this.
  6. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    You would block the rear view camera, same thing that happens on any vehicle with a trailer and a rear view camera.
    As far as the Intelligent Clearance Sonar, I would guess that (with the European wiring that Toyota sells - not useful here unless you would wire your own trailers to the European standard) either the trailer is detected (based on current draw, most likely) and it's automatically disabled, or if it's not detected or you don't have that wiring, you just turn it off in the multi-information display (I'd have to check a European manual to see whether it can actually detect a trailer, though) - the US owner's manual says how to turn it off.
  7. fotomoto
    fotomoto Senior Member
    5,602
    3,781
    So. Texas
    A) You look out the back windows and use the mirrors like you're suppose to.
    B) They only activate (beep) in Reverse.
    I like to use the rear view camera to check my load on my CMax (not tow rated but 3rd party hitches are available).
  8. KeinoDoggy
    KeinoDoggy Member
  9. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    Lots of cars in Europe are rated to tow when they're not rated to tow here, because of European tow ratings often not accounting for much beyond whether the car can start uphill on a grade.
    Curt has a hitch available, but I'd want to see another couple chassis attachment points added to it, to mirror how the Toyota European market hitch attaches to the chassis.
  10. priusdonkey
    priusdonkey Member
    211
    51
    Los Angeles, California
    The Curt is a nice hitch. Somewhat involved to install yourself tho.
    ATHiker likes this.
  11. helmkera
    helmkera Junior Member
    51
    Sandwich, Illinois
  12. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    When trailer light / brake wiring is plugged into my 11 F150, the proximity sensors are automatically deactivated.
    RCO likes this.
  13. thewraith
    thewraith Junior Member
    67
    23
    DC Metro
    Same thing that happens on my tow rig- you simply don't use the rear camera. There is a button on every one of my other cars to disable the proximity sensor- there has to be one w/this package.
  14. bwilson4web
    15,561
    Could some of our UK owners check on the tow package part number and price?
    I might be interested in buying one.
  15. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,321
    Central Virginia
    For Gen 4? It may not necessarily fit the Prime. At least, not without modification.
  16. au_prius
    au_prius Australian Prius Driver
    67
    55
    Australia
    I am interested as well... The official Toyota Australia line is that PRIUS isn't approved for towing. I wonder if the UK models have specific ECU firmware or other modifications to allow towing?
  17. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    The Prime's significantly longer, so the European towing package hardware may not be the best bet for it...
    Also, it's not going to give you an American-style receiver, it'll instead give you a swan neck ball.
    The towbars are PW960-47000 for a fixed ball (bolts to the towbar), or PW960-47001 for a removable ball.
    Installation instructions for PW960-47000: https://www.toyota-tech.eu/aimuploads/ddb78e80-fa88-40cd-935f-c979fce0f76a/Prius_THF_PW960_47000_AIM_003_556_0.pdf
    And for PW960-47001: https://www.toyota-tech.eu/aimuploads/928183ed-f94b-4315-b786-724a4f9af782/Prius_Towing Hitch Detachable_PW960-47001_AIM 003 554-1.pdf
    You'll need to copy and paste that second URL, the forums aren't cooperating.
    #17 bhtooefr, Feb 14, 2017
    bwilson4web and RCO like this.
