Toyota Announces Bioplastic With High Impact Resistance
Discussion in 'Gen 4 Prius Main Forum' started by usbseawolf2000, Jul 26, 2014.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Toyota Boshoku Corp and Toyota Central R&D Labs Inc co-developed a bioplastic whose impact resistance is about 10 times higher than that of polypropylene (PP) used for auto interiors and announced it at JSAE Annual Congress (Spring).
    According to the two companies, the improvement in impact resistance might drastically expand the use of bioplastic. In regard to auto interior parts, it is possible to use the new bioplastic not only for door trims and other parts for which currently PP is used but also for the base materials of instrument panels, impact energy absorbers and other parts that need high impact resistance and rigidity to protect passengers at the time of impact.
    Furthermore, the new bioplastic is expected to be employed for auto exterior parts such as bumper modules and resin fenders.
    Source
    If we assume the "current bioplastic" is what's in the current gen3 Prius, no wonder they are easily scratched. The new version is harder than ABS plastic!
    I am speculating it will be used in Gen4 Prius.
  2. Mike500
    Mike500 Senior Member
    2,593
    764
    The Charpy impact test has little to do with scratch resistance.
    It has to do with frangibility and fracture. Polypropylene, currently used in interiors of cars, is not particularly scratch resistant. It is, however, very impact resistant and cushions the blow by deforming rather than fracturing.
    Tenacity and the ability to deform without fracturing is the most important characteristics needed in passenger compartment materials. The Charpy test determines the ability of materials to deform without fracturing.
    Hard unforgiving materials that are scratch resistant are more likely to fracture. Glass and other ceramics, while hard and scratch resistant, are not particularly fracture resistant.
    #2 Mike500, Jul 26, 2014
    49,492
    but can you clean it?:cool:
  4. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    Yeah and is it high or low gloss? Oh while we're on this subject, ditch the graining of the plastic dash. Makes it hard to clean & gets dusty early.
