Toyota app updated again (sigh!)
Discussion in 'Prime Main Forum (2017-2022)' started by pghyndman, Dec 16, 2022.
  1. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Toyota app updated today to Version 2.0.14. Somewhat different layouts, no readily notable improvements for Prime owners but seems to have lost the Guess-O-Meter display.
  2. schja01
    schja01 Senior Member
    1,827
    1,218
    Chicagoland
    2024 Prius
    Limited AWD-e
    Big improvement in iPad formatting.
  3. SidS1045
    SidS1045 dumber than a box of hair
    17
    Stoneham MA
    2022 Prius Prime
    ….aaaand it’s still useless. Won’t even take my VIN number, whether scanned, copy-and-pasted or typed in manually.
    Graz likes this.
  4. schja01
    1,827
    1,218
    Chicagoland
    2024 Prius
    Limited AWD-e
    I’m not seeing this. They added Eco Charging info which personally, I don understand.
  5. CharlesH
    2,796
    1,163
    Roseville, CA
    I *THINK* that they finally fixed the Vehicle Finder functionality on the Toyota App for my 2017 Advanced. The map that comes up with the bottom row Find button now has two dots: one for "You Are Here" and the other I *think* is the long MIA "Your Car Is Here" dot. I have been working with Toyota Brand Engagement for months on this, ever since the Entune App was discontinued in favor of the Toyota App. I have to double check this a bit more to confirm. If one is near the car, you may not see the other dot, since they may overlap.
    What has changed from how this worked in the Entune App is that there apparently is now no way to force a location update. With the Entune app, you could hit a "Refresh" button to have the system contact to the car for its current location, even if it was moving. Now, I think that the car sends the location info only when you turn off the car.
    In any case, I can confirm that Safety Connect functionality still works in my car after Verizon turned off their 3G (CDMA) network on January 3. We were pretty sure that the 2017 model has a 4G Safety Connect phone, but this confirms it.
    #5 CharlesH, Jan 7, 2023
    pghyndman likes this.
  6. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    So I have a 2017.... last time I had connected services I had Entune (yea, it was a while ago). Are you still able to control the AC from the app? If so, I may sign back up.
  7. schja01
    1,827
    1,218
    Chicagoland
    2024 Prius
    Limited AWD-e
    I have a 2018 and can.
    Tha_Ape likes this.
  8. CharlesH
    2,796
    1,163
    Roseville, CA
    I have the same A/C option for my 2017.
    BTW, The remote functionality on the 2017 is different from the 2018. For the 2017 Prime, they hacked support for remote functionality into Entune. The Remote Connect stuff was completely redone in 2018. For example, there is no remote start or remote lock/unlock functionality on the 2017. Then they got rid of the Entune App completely, and merged everything into the Toyota App, gradually tweaking their back-end system and app to play with the Entune-related software in the older models.
    #8 CharlesH, Jan 9, 2023
  9. schja01
    1,827
    1,218
    Chicagoland
    2024 Prius
    Limited AWD-e
    There’s no remote lock/unlock on my ‘18 either.
  10. CharlesH
    2,796
    1,163
    Roseville, CA
    Thanks for the clarification. I guess that came later.
