Toyota Aqua/Prius C Not Switching To Ev
Discussion in 'Prius c Main Forum' started by Aizaz, Jul 23, 2019.
  1. Aizaz
    Aizaz New Member
    Pakistan
    2013 Aqua
    Hello Guys, I am fom Pakistan. The Problem which i have with my Prius C is that Its Ev mode is not working and the engine is running all the time.When I start the car it starts normally but when i shift the gear to D the engine kicks in automatically,even if the battery is full. When the gear is set to P then it switches back to Ev.I have changed the hybrid battery but it was of no use, then i changed the inverter, the blower of the battery but still i am facing that issue. I dont know what to do now. Kindly Guide me. There is no check light in speedometer.
    52,370
    welcome!
    do you have tech stream diagnostic software?
    any trouble lights?
    how is the 12v health?
  3. Brad K
    Brad K Member
    173
    53
    could be too hot inside the car, run the AC and check the battery vents to make sure clean and not blocked
