Toyota Aqua radiator fan continuesly working
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Ranchoz, Sep 2, 2021.
  1. Ranchoz
    Ranchoz Junior Member
    North Carolina
    2012 Aqua
    vehicle - Toyota aqua
    year - 2012
    Im from Sri Lanka. Toyota aqua radiator cooling fan working continuously once I pressed the power button with maximum speed. this was replaced with a brand new radiator after a car crash. no fault in fan control module. no matter if the a/c is on or off fan is working maximum speed. no check engine sign. could it be inverter related fault?
    49,498
    temp sensor?
  3. ChapmanF
    15,622
    Wiring diagram. The circuit isn't complicated, and it's overwhelmingly likely a simple mistake was made while replacing the radiator, but finding the issue by referring to the wiring diagram would be the fast way, and trying to do so without it would, probably, not be.
  4. Ranchoz
    North Carolina
    2012 Aqua
    it would be the next step. not sure if the fan control module is working properly
    no any fault code for tempreture sensor. still could not diagnose
    #4 Ranchoz, Sep 4, 2021
  5. ChapmanF
    15,622
    Do you suppose there is a fan control module? You'd probably see it on the wiring diagram.
  6. Ranchoz
    North Carolina
    2012 Aqua
    actually i could not find any wiring diagram on internet. do you have ? can you kindly provide
  7. ChapmanF
    15,622
    There's a wiki page here where Elektroingenieur kindly collected a lot of information about access to the technical documentation including wiring diagrams.
