Toyota ends three-year lithium-ion tests, Decides to stick with NiMH for the future (for now).
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Rybold, Sep 14, 2009.
  1. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Toyota's been sneaking around on Nickel-powered Priuses behind their back, performing a 3 year, 126 car road test of Lithium Ion batteries in the 2006 Prius. The results? The cost doesn't justify the "small" fuel economy gains. Here are all the details from Bloomberg:
    Sept. 14 (Bloomberg) -- Toyota Motor Corp., the biggest seller of hybrid cars, is sticking with nickel as the preferred battery material for most of the vehicles after three years of secretly testing Prius hatchbacks with lithium-ion packs. Toyota last month ended road tests of 126 Priuses in the U.S., Japan and Europe that began in 2006, company spokeswoman Jana Hartline said in an interview. Details of the program, in which the cars’ nickel metal hydride batteries were replaced with more expensive lithium models, haven’t been released. Automakers including Toyota are introducing models powered completely or in part by lithium-ion batteries, which can hold twice the energy of nickel packs. While Toyota’s lithium batteries performed well and yielded “small” fuel-economy gains due to lighter weight, nickel will remain the material of choice for conventional, mass-market hybrids as lithium’s benefits didn’t justify the higher cost, said Kazuo Tojima, the carmaker’s senior staff engineer for batteries. The Toyota City, Japan-based company’s tests showed lithium’s “durability, stability and safety are assured,” Tojima said. The tests appear to be among the most thorough done by companies planning to introduce the batteries, said Menahem Anderman, president of consulting firm Advanced Automotive Batteries in Oregon House, California. “We now know that a lithium-ion battery can work; that’s not really the question,” he said. “Cost is critical, and we still don’t know enough about long-term durability.”​
    Sounds like the wait continues until the 3rd Gen Prius is coverted over to Li-ion.
  2. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    Wow...but this makes sense from everything we've seen and heard from Toyota thus far. It appears that Toyota PHEVs will go forward, else they wouldn't be debuting them at Frankfurt, it's just that the main emphasis will still be the NiMH technology due mainly to cost reasons.
  3. bwilson4web
    16,012
    The only data point I have are my battery refurbishment experiments. I found that simply adding water was all it took to restore NiMH batteries to like new, actually a little higher, Ahr capacity. I don't know enough about LiON battery chemistries but I suspect they are not so easily restored to 'like new' capacity.
    I understand from Wiki that the critical NiMH patents will expire in 2014 and the bones of Cobasys will turn to dust and a bad memory. A patent system whose purpose should be to spread technology and afford the inventor some profits will have once again been the dog in manger.
    I have only one thought about the USA patent system and that is to require a fixed rate fee system. Say 2-3% of the gross sales based upon capacity of the product. The inventor gets a fair return based upon gross sales of products using their idea. But the big thing is banning or blocking of product becomes a thing of the past.
    4 people like this.
  4. dogfriend
    7,512
    1,189
    Carmichael, CA
    I would add that the original patent cannot be transferred or sold from the original assignee. That would shut down the patent troll business.
    Re: Toyota sticking with NiMH
    I think this may also be a strategic move in that Toyota has already assured a supply of Ni to build batteries, but I have read that the Lithium may become a supply issue in the future as it is concentrated in a few areas (e.g. Bolivia).
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    In a similar vein, refusing to license a patent for a reasonable fee should void the patent and turn the invention over to the public domain. Defining "reasonable" would be the tricky part. Perhaps Bob's 2-3% comment is really saying the same thing.
    I would also do something like this with copyrights. If an author isn't going to publish something, someone else should be able to do it. Many works remain out of print due to copyright disputes. Set a statutory amount and the problem goes away.
    Tom
  6. Wooski
    Wooski New Member
    241
    63
    London, UK
    This makes total sense for the standard hybrid model. The Plug in will have to be Lithium and as we can see from others comments, the plug in will only suit some people's needs (though a significant majority I wager).
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    The good news is that Toyota's Li-ion battery is durable, stable and safe. The bad news is that the extra cost does not justify the small increase in MPG.
  8. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    So the hybrid as envisioned by Toyota gains little from lithium, and they aren't changing their vision for now to match the electrical range of a Volt. I guess that's OK, but it seems like a PR problem down the road when the Prius no longer seems modern...
  9. Rybold
    2,760
    322
    Southern California
    Heck, the bottom line is MPG. If Toyota can hold that title, that's what will matter. I suppose it would be good from a competition/innovation standpoint if Toyota sticks with NiMH and others go with Lithium-Ion, and down the road we really get to see which is better (competition does not muffle results).
  10. Tideland Prius
    16,445
    Methinks Toyota has something else in mind. MB and GM are charging ahead with Li-Ion hybrids and Nissan with the Li-Ion-equipped Leaf. I think Toyota has something else in its development to leapfrog Li-Ion. How much is anyone's guess but I don't think Toyota would follow (otherwise, the Prius wouldn't be a Prius if it was using technology that other cars have, right?)
  11. Rybold
    2,760
    322
    Southern California
    I think it comes down to two things: 1) A core characteristic of Toyota, which many associate the company with, is reliability/dependability, and with NiMH having been proven over a decade in the Prius, Toyota is maintaining the dependability of the NiMH in hybrids, which have proven themselves.
    2) Lithium Ion is more expensive, and another characteristic of Toyota is price manufacturing efficiency. By sticking with a dependable, reliable proven technology that has become mass-production with Toyota's efficiencies, it will help keep the Prius production efficient, PROFITABLE, and cost-effective for consumers.
    *note Nissan has three more EVs, in addition to the Leaf. They were announced yesterday by Nissan-Renault CEO and will be put into production (there is another thread on this).
  12. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    most people didnt read the article properly:
    a. Toyota said that nickel is better because of the cost, for standard hybrids, not phevs.
    b. they feel assured about durability, safety and reliability of lithium-ion batteries.
    so only problem is cost - you dont gain enough to offset the costs in regular hybrids.
    Also, test was run from 2006.... You can just see how far ahead Toyota is when they were doing 3 year tests on lithium-ion batteries in 2006 while all these companies are skipping testing and will ust try to sel cars in 2-3 years from now.
  13. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    Yes, it is a shame we have to wait that long. There is some good news....
    http://www.ovonic.com/PDFs/Financial_Reports/form_8k/8k_mbi_patent_infringe_settlement_7july04.pdf
    If you read this carefully (backed up by the Wikipedia article on Cobasys) Panasonic and Toyota can act sooner, they can sell large format batteries NiMH in cars in the second half of 2010. This is a big deal because GM, Ford and others can not. The others have to use non NiMH until 2014.
  14. jprates
    jprates https://ecomove.pt
    387
    42
    Moita, Portugal
    2017 Prius PHV
    My feelings exactly, thanks for saving me a lot of keystrokes!
  15. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Did anyone here doubt that Li-X is more expensive than NiMHydride ? Or that Li-X's superior performance characteristics would not matter in our Prius type hybrid use ?
    All that was non-news. Safety and short term reliability through the test was good news though, and will hopefully continue into a PHEV future.
  16. mikepaul
    1,763
    Columbia, SC
    I just see future commercials: "And we use the new lithium technology, much more advanced than some of the competition uses. Maybe change scares them..."
  17. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    I think it's because Toyota has invested too much money in making it's own batteries, it needs a few more years to ROI it's plant.
    Probably in 2-3 more years it will have to reconsider.
    Me, my personal favorite option is three-fold :
    - an UltraCap for the brake regen, that delay-feeds into the NIMH pack
    - an NIMH pack that's recharged from the ICE & regen
    - an LION pack for the plug-in, that feeds the NIMH pack.
    - whenever the NIMH is full, the amps bleed into the LION pack
    Similar to the Enginer PHEV, but integrated into the current HV pack. Basically halve the NIMH batteries and put in the other half LION.
  18. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    Like sage said, nothing really shocking here. There are lots of people out there who expected the Prius to suddenly get amazing mileage gains as soon as Toyota got rid of those boring old NimH and upgraded to shiny new Lithium. The reality is the NimH batteries are very well suited to the small capacity batteries needed for HEVs and short range PHEVs. Much of the buzz around lithium is either marketing hype and/or simple necessity due to the NimH patent situation. Its amazing how much damage that patent did to the EV industry. The situation starts to change when you get to long range PHEVs and BEVs, but even then large scale NimH doesn't suck. If it hadn't had its hands tied behind its back for the last 10 years it would probably suck even less.
  19. tochatihu
    tochatihu Senior Member
    9,549
    3,685
    Kunming Yunnan China
    2001 Prius
    "Its amazing how much damage that patent did to the EV industry."
    This is true and probably more true than we can yet realize!
  20. clett
    clett New Member
    537
    Scotland
    Yes, NiMH is around $500 per kWh just now, whereas LiFePO4 is around $300 per kWh.
    Also, because LiIon can have a higher power density than the NiMH used in the Prius etc (3 kW per kg vs 1.3 kW per kg), a smaller battery (read cheaper) can be used to achieve the same power output, which is what really matters for current generation hybrids.
    The reason Toyota cites cost as an issue is because they don't have a huge LiIon factory yet, whereas their partner PEVE does have a fully scaled NiMH factory. If they had a different battery partner it would be a different story.
