Toyota is the new Audi
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by zenMachine, Aug 28, 2010.
  1. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    2 people like this.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Great piece.
  3. Mike_10
    Mike_10 Member
    73
    Boston MA
  4. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    give me a cookie dammit!
    this is what is said months ago about this being another "audi 5000".
    i lived through it back in the 80's
  5. wwest40
    wwest40 Member
    518
    Pacific NW
    2003 Prius
    I
    Assuming you haven't noticed, regardless of the Audi cause, a very good feature, non-intrusive feature, came about as result, you now need to depress the brake pedal firmly in order to shift out of park.
    Now it's time for a "second" edition of that fix. Reprogram the DBW such that the gas pedal doesn't work to suddenly/QUICKLY go WOT (easy/slow depression to WOT would still work) unless the brake pedal was first released, "just" released, or the car is already moving at some minimum speed based on the acceleromter, not wheel speed, "speedo".
    Mistake the gas pedal for the brake pedal in a panic situation, guess what, the gas pedal DOES NOTHING.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    I wouldn't want a system that keeps me from using full throttle when I want or need it, if that's what you were referring to. It would be better if people would learn where their feet are, that's been working fine for me.
    I have ridden with people who completely take their feet away from the pedals when they use the cruise control, I think that might make it harder to find the brake in an emergency.
  7. LeadingEdgeBoomer
    289
    29
    New Mexico
    Good article cited by the OP. Note also that Audi did not die from bad publicity. I read recently that Audi outsells BMW in that market sector across Europe. Seem not to have been damaged by being in the VW fold. However, the reliability of my '01 A4 has been disappointing, which led me back to Japan, Toyota, and Prius.
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Audi was harmed so bad it was scooped up by Ford.
  9. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Huh?
  10. LeadingEdgeBoomer
    289
    29
    New Mexico
    Nope, you're thinking of ?????
  11. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    Audi has been wholly owned by VW since 1964.
  12. hill
    8,177
    Gee - I never let Toyota chop my Prius' 2004 accelerator pedal shorter. Does this mean I can sleep easy again? Oh wait . . . I never lost any sleep.
    I'll be saving this article for when/if ever our favorite GM dealer, malorn returns .... and remind him how he prophesied this would be the end of Toyota.
  13. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    "See what happens if you throw your car in neutral under full throttle"
    I can second this. While test driving a Gen III Prius I did exactly this. I shifted it into neutral while driving. It worked just fine.
    HOWEVER... I do have to say that with my Corolla, I feel a CLEAR physical connection to my transmission when shifting into neutral. With the Gen III Prius, I still felt like I had to direct my "request" to through the computer.
  14. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    That's because the computer *is* the transmission on the Prius, so to speak. With nothing mechanical to shift, all you get is a link to the electronics.
    Tom
  15. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Yep, Audi is the new BMW. BMW have lost their way and Toyota sales are on the up.
    Only down side is that Audi's are now more likely to be driven by 25 year old hot head junior managers with attitude! :eek:
    Funny what 3500 miles of ocean makes.
  16. hill
    8,177
    I've show this article to numerous Toyota haters I have the joy of working around. Here's their take:
    "See? ... That just PROVES the NHTSB is on the take ... because there's NO way that all those drivers could be stupid".
    :rolleyes:
  17. bwilson4web
    15,518
    ROTFLMAO!
    "Oh, so they were bright enough to buy a Prius?" <GRINS>
  18. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Well, I agree it's the drivers fault. BUT, in the Audi case it was proven that the "cause" was the two pedals were too close together, allowing the confusion. Don't try to tell me that is no excuse, because I'm not making one. It's a fact of life that "the unwashed public", who Toyota sells to, can be easily confused. I haven't read a study of the Toyota cars yet to see if pedal placement is causing confusion.
    What we got out of this is not as wwest posted. In the Toyota Hybrids we got no change, other than some pedal cutting and ensuring the floor mats were properly secured (a "good thing" tm). In all other Toyota vehicles we got a system that drops the engine to idle if the accelerator is pressed and held, then the brake pedal is pressed. It's a firmware system, not mechanical. We didn't get it "added" into the hybrids because it was already there.
    I believe this system is also a "good thing" tm.
    Oh, and I also predicted this. Do I get a crystal ball medal too? ;)
  19. wwest40
    wwest40 Member
    518
    Pacific NW
    2003 Prius
    I
    "...when I want or need it..."
    Using the technique as described under what non-exceptional circumstances would the suggested DBW throttle NOT respond as you expect....?
  20. darelldd
    6,057
    389
    Northern CA
    Hill... don't you have a bridge to sell these brilliant people?
