Toyota issues recall for 2016-2018 Prius
Discussion in 'Gen 4 Prius Main Forum' started by Larry Greenwald, Sep 5, 2018.
Tags:
Thread Status:
Not open for further replies.
  1. Larry Greenwald
    Larry Greenwald Junior Member
    67
    16
    2018 Prius
    Toyota has issued a recall for Prius units for model years 2016-2018 to fix an issue that might cause a fire. It affects Prius units built from sometime in 2015 thru May of 2018. It's a free fix once you get the recall notification.
    I'm linking in the first article I found from a Google search on this topic:
    Toyota recalls Prius to fix defect that could trigger fires
    Moderator: if and when you see this, please make this a STICKY and OK to copy to any other Prius threads as necessary,
  2. Larry Greenwald
    67
    16
    2018 Prius
    FYI, I recently leased a 2018 Prius 3 and it has a build date of 04/2018, so I'm definitely affected.
    52,256
    will you continue to drive it until it is repaired?
  4. Larry Greenwald
    67
    16
    2018 Prius
    I don't drive that much anymore. In the month I've had it, I've only driven a little over 500 miles. Some days it just sits there all day unused. I just need to be cautious and get to the dealership ASAP after getting the notification. FYI, I checked at Toyota's recall site and there's no fix yet available for my car.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    There are 2 previous threads on this started yesterday - they've been amalgamated, I've requested this be added to it.
    I wouldn't be overly concerned - it's talking about wearing through, and more likely to be affecting high-mileage cars. Just wait for the recall advice. Consumer Reports describes it "Wiring in the front of the vehicle could wear over time " - particularly seeing yours has only done 500 miles in a month - there are some which have done over 100,000km, and others are almost 3 yrs old.
    Michael Shafer and krmcg like this.
  6. Tideland Prius
    16,594
Thread Status:
