Toyota makes structural upgrade to Gen 4 safety cage
Discussion in 'Gen 4 Prius Main Forum' started by JosephG, Aug 23, 2018.
  1. JosephG
    JosephG Active Member
    114
    101
    2018 Prius
    This is mainly a heads-up to potential new buyers. Toyota has made a structural upgrade to the safety cage in the Prius. To determine if a car you're considering has the upgraded safety cage, look at the manufacture date found inside the driver's door on the B-pillar. Cars made after May of 2018 have the new structure.
    The IIHS is now crash-testing cars on both the driver and passenger side because they found many manufacturers were only enhancing the safety cage on driver's side. Toyota added a brace to the lower hinge of the passenger door before submitting the Prius to the passenger-side test.
    Smaug1, RCO, skayaks and 8 others like this.
    49,847
    important finding for many car shoppers, thank you!(y)
    RCO likes this.
  3. Leadfoot J. McCoalroller
    7,322
    6,835
    Pennsylvania
    2018 Prius c
    Nice move, mouse!
    Cat? It's your turn again. Cat?
  4. alanwagen
    alanwagen Member
    121
    79
    FORT WORTH
    2018 Prius
    Ok ours says exactly 05/18. So is that inclusive? Just checking. Thanks
  5. JosephG
    114
    101
    2018 Prius
    Not sure, it may have changed mid-month so there's no real way to know.
    I wouldn't worry if you're already purchased the car, the vast majority of real-life small-overlap crashes are on the driver's side.
  6. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    On off topic! Is the 2019 offering anything significant?
  7. Leadfoot J. McCoalroller
    7,322
    6,835
    Pennsylvania
    2018 Prius c
    Why not peek at the lower right front door hinge? 50/50 chance the part is visible. Might need to compare some pictures.
  8. Starship16
    Starship16 Senior Member
    1,348
    1,454
    Beach Christmas
    That's why I never have a co-pilot in the front right seat.
  9. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,585
    near Brisbane, Australia
    All rumour at present:
    A it of (often random) reading:
    2019 Prius restyling | PriusChat
    ETP and Starship16 like this.
  10. Starship16
    1,348
    1,454
    Beach Christmas
    They added the Prime headlights to the standard Prius? Looks good.
    One article said there may be two versions of the new engine, with a 2.5L being an option? Probably the same engine as in the Hybrid Camry. That would make me drive too fast. ;)
    ETP likes this.
  11. alanclarkeau
    7,044
    7,585
    No, I think it's a 1.8 modified with the same modifications which were made to the 2.5. There was mention that the Corolla 2.0 could make it - but it's l/100 (MPG) score is poor in comparison (24% higher).
    ETP likes this.
  12. ETP
    2,802
    1,170
    Auburdale FL
    That is the best seat to fly an aircraft for a right hander.
  13. alanclarkeau
    7,044
    7,585
    I find it's better to drive from the RT Front seat.
    Since2002 and ETP like this.
  14. ETP
    2,802
    1,170
    Auburdale FL
    That's the size map I need.
    We fill up here, dump our load here and go home to fight another day. Just like a garbage truck.
    Like the evil cat look on the front.
    If they manage to improve the MPG it will be 7 consecutive miracles.
    #14 ETP, Aug 31, 2018
