Toyota manual instructions for entering Diagnostic mode
Discussion in 'Gen 2 Prius Technical Discussion' started by Syclone, Aug 13, 2006.
  1. Syclone
    Syclone Member
    540
    I don't know if this was ever posted. I couldn't find any reference in a search.
    Toyota has directions for getting into diagnostic model in the Prius manual.
    Also, while looking through the manual (on CD) I discovered that there is an in-line antenna amp in the headliner just above the rear passenger door.
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Search for "inspection mode".
    http://priuschat.com/forums/kb.php?mode=article&k=25
    If you just want the engine to idle, you don't really need this -- push
    the go-pedal while powered up in normal PARK, and the engine lights
    and revs a little. If you brake+shift to N *while* it's running,
    it will settle back down to idle and stay running. So for starting,
    revving up, and idling, the normal functionality of the car may be
    completely sufficient.
    _H*
