Toyota Owners, Transmission fluid
Discussion in 'Gen 2 Prius Main Forum' started by GeorgeMW, May 22, 2018.
  1. GeorgeMW
    GeorgeMW Junior Member
    57
    Georgia
    Hello, i have an '06, the toyota owners site (which allows us all to check for the things the dealer has done to our cars using the VIN code) doesn't display whether the transmission fluid has been changed or not, the car has 85k miles, could you please inform me on how to tell, whether the fluid has been changed or not?
    thanks in advance.
    p.s. there is no dipstick.
  2. Mendel Leisk
    40,583
    If it had been changed it most likely would be indicated, so I would assume it hasn't.
  3. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Just change it, then you know. DIY: ATF WS and the two washers should be about $40 at the dealer parts counter. My dealer has changed mine for about $90 to $110.
