Toyota Plug-in availability stepped up
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Fibb222, Aug 29, 2008.
  1. Fibb222
    Fibb222 New Member
    1,499
    99
  2. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    Very cool, hope its true.
  3. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    "Toyota is moving up the rollout of a plug-in hybrid for fleet purchase to late 2009, up from an earlier estimate of sometime in 2010."
    Perhaps this means that "sometime in 2010" is when the plug-ins will be available to consumers! :)
  4. Unlimited_MPG
    Unlimited_MPG Member
    218
    24
    Federal Way, WA
    My concerns is what the range of electric only will be? From the sounds of it only 7 to 10 miles for the "fleet" models. Sounds like they plan a longer range for the "consumer" models. But I hope that range is far enough or else they could potentially lose the #1 hybrid spot to some others that are coming out with new Hybrids / EV.
  5. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I"m not concerned with the range as long as the same recharge-while-driving is in place. Shoot, I'm averaging 70MPG with very limited stealthing range at speeds under 40mph. Give me 7-10 miles at up to highway speeds and I'll show you 100+mpg!
  6. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Exactly, I look forward to being able to exploit extended EV capability.
    I guarantee I'll exceed the advertised electric range.
    And it must be rechargable while driving, as it is now, in addition to Plug-in capable.
  7. Rybold
    2,760
    322
    Southern California
    I'm not arguing, I'm simply asking for some discussion/enlightenment. As opposed to driving 7-10 miles on EV only and then switching to hybrid, wouldn't it be more efficient to continue to use the Prius as it already operates, except to increase the proportion of work that the EV does before the ICE kicks in? In other words, there would not be an "EV only switch," and instead the Prius would always be in hybrid mode.
  8. Flying White Dutchman
    4,376
    313
    i hope the release will be even sooner
  9. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    this was official from toyota about their next year plans, they are speeding up hybrids and electric vehicles...
  10. daniel
    14,487
    1,519
    Spokane, WA
    Has Toyota announced the actual specs for the PHEV Prius? How fast will it go in EV mode? How far will it go on grid power before using gas? Unlike some of the above posters, who merely want better mileage for their gas, I want a car that can drive on grid power alone up to some reasonable distance. Ideally, all in-town driving, including freeway, is grid powered, and gasoline only begins to burn when you take a road trip.
    With a very short EV range, plug-in becomes pointless. What's the point of plugging in if it only saves you an ounce of gasoline per charge? Added battery capacity seems to give the Prius better FE, and that's good. But plug-in is useful when it means that a significant portion of your driving is powered by the grid: Imagine driving on grid electricity 11 months of the year, and only burning gas for your yearly vacation to Baja.
    I save 3/4 of a gallon of gas every time I drive downtown in my Xebra instead of my Prius. That's because the Xebra plugs in and runs on grid power. If the Prius did that, I would not need two separate cars, one for city and one for road trips.
  11. Unlimited_MPG
    218
    24
    Federal Way, WA
    I couldn't agree with you more! Toyota really needs to take the next step to meet the needs of the consumer. They have done very well so far, but they need to take that next step soon.
  12. Tideland Prius
    16,445
    I just hope a PHEV just means a battery with a larger capacity to hold a charge. This means more recouperation down the mountain and, along with the solar panel option, longer times with the A/C on before the engine has to come on to recharge the traction battery.
  13. daniel
    14,487
    1,519
    Spokane, WA
    For plug-in to be of any use, it would require a very large battery capacity. Assuming regen braking, that battery should indeed be able to capture a lot of energy on downhills. The real question is whether Toyota is going to give the PHEV Prius enough battery capacity to make plug-in worthwhile. Right now battery capacity is expensive, and for the mass market, cost is a big factor. However, as gas prices rise, the cost differential between gas and electricity will make batteries more appealing. Without a major breakthrough in electric storage, it may be a few years before gas prices rise enough to convince consumers to pay the extra cost for batteries.
  14. Rybold
    2,760
    322
    Southern California
    Daniel, thank you. You answered my question, and the answer is that "EV mode" is a step towards fully-electric cars, independent of petroleum. (except for a backup generator - in which case, we may be able to use biodiesel)
    Hasta La Vista OPEC !
  15. sola
    sola New Member
    27
    Budapest, Hungary
    The plugin could be very useful for some people even with only the hybrid battery. You can for example have the battery constantly topped up so you get the best performance immediately when you start driving the next day.
    The plugin is also NOT useless with a 10mile charge-depleting battery. This is for example within the range of my working place. I will drive completely electric one way and in hybrid mode on the way back (every day of the week).
    Much more important that the plugin Prius will probably be designed to be completely without the ICE and handle as normal car in EV mode. Conversion kits based on that platform will not bump into the limitations of the current Prius. As far as I know, the PGP will be higway capable in EV mode.
  16. daniel
    14,487
    1,519
    Spokane, WA
    Is this your personal speculation, or has Toyota made an announcement about this? I ask because I was pretty much cut off for the past two months. I had internet access, but it was too slow for anything but checking my email and posting a very few pictures. So I may have missed an announcement. But I was not aware of anything official from Toyota. Just a lot of unfounded speculation from folks who watch the auto industry.
  17. Tideland Prius
    16,445
    I believe that statement was from a long while ago (~ when Porsche also claimed their Cayenne Hybrid will do 70mph in EV Drive Mode). I haven't heard anything from Toyota or the media since then.
  18. drees
    drees Senior Member
    1,782
    247
    The majority of my errands are within 5-6 miles. 10 mile range would let me do most of my errands on battery. Could do the whole thing if the shops I frequented had charging stations.
    My commute is a bit over 20 miles, so 10 mile range would reduce fuel consumption by 25%, and reduce it by 50% if I can plug-in at work. And I'm looking to move within 10 miles of work so when that happens I could potentially do the whole commute on electricity.
    Other trips that are significantly farther than that occur very infrequently, perhaps a dozen times a year or so, and then they tend to be between 100-500 miles so we'd need a huge pack to have any significant portion of those trips use electric power.
    Though I do admit, that with 20 mile electric range, that would probably cover well over 90% of the driving I do.
