Toyota Prepaid Maintenance Plans
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lmgeee, Mar 14, 2012.
  1. lmgeee
    lmgeee Junior Member
    Whittier
    I just bought a new 2012 Prius Two. Is the Toyota Prepaid Maintenance Plan worth it? What is your experience with these maintenance plans when you go to the dealer? It looks like they don't cover all items. Is that correct? Thanks :)
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    It used to be a better value in the past when oil changes were required every 5k miles. Nowadays, you can simply take it in every 10K and service it yourself (including inspections, engine and cabin air filters) in between and save more money compared to buying the prepaid plan.
    chinarut likes this.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Not worth it...!
  4. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    I drive 600 miles a week, I got a 2 yr plan from my dealer, no cost to me, I will be in there every 4 months getting my service done.
  5. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    I think it depends on how much you will be paying and whether you can do the work yourself. I have no plans on crawling under the car to do any work, so I paid something really cheap for the additional years of maintenance (I don't recall how much I paid, but I thought it was less than $300). If you can and desire to do all of your own maintenance after the initial free 2 years (they are still doing this, right?), then it definitely isn't worth it. I'm getting too old and I'm too lazy to do it myself. They also rotate the tires, which can be a real pain to do yourself.
    Mike
  6. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    You can skip the tire rotations every other 5K miles and just have that done when you take it in for oil changes every 10K (there's no warranty on OEM tires anyway). No need to crawl under the car to do engine and cabin air filters change (which is very easy to do). You'll still save money over the prepaid plan.
  7. DumbMike
    560
    119
    Los Angeles
    FYI, while I was spending all of this money on my new car, I also bought some tire insurance/warrany against road hazzards. And just last month I got a screw in one of my tires. I'd already driven about $20K on the tires. The cost for the one tire was $140 but the insurance paid $130. I have no idea what underpayment of $10 was for, but I really didn't care. Unfortunately, I don't recall how much I paid for the insurance/warranty, but it wasn't much.
    FYI, I later learned that the tire guy at Costco told the warranty people that the screw was in the sidewall. It was actually in the middle of the tread. The Costco guy said that because otherwise, the warranty people would make them plug the tire rather than put a new one on.
    Sorry for going off topic.
    Mike
  8. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    I had the same issue with my Prius. I got a screw in the Tire and I went to the local mechanic and he charged me $10 to remove the screw and plug the hole. I am sure glad I did not pay $100 for a Tire warranty.
  9. Judgeless
    1,821
    255
    Cleveland, OH
    I do not know how much it cost for the pre paid maintenance. This is what needs done up to 75,000 miles.
    The Prius comes with a free 25,000 pre paid maintenance.
    0 to 25,000 miles cost $0
    30,000 miles oil change $50, replace cabin and engine filter $30
    40,000 miles oil change $50
    50,000 miles oil change $50
    60,000 miles oil change $50, replace cabin and engine filter $30
    70,000 miles oil change $50
    Total $310
    Everything else is inspection. If they are quoting less than $310 you have a good deal. If not tell the finance guy trying to steal money from you he is a scum bag. All dealers are scum bags that use FUD to make people pay more money.
  10. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    So basically you paid the same as it'd cost to plug it ($10), but at least the Costco people took advantage of the system for you.
  11. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    Not for him !!!! For them selves !!! One extra sales !!! they made a lot more money on that than would have on the simplest repair....
    They do not care if HE has a new tire or not !!!
  12. dbldbl
    dbldbl Junior Member
    34
    Midwest
    I bought my Prius when Toyota was trying to reassure everyone with the stuck accelerator stuff. That was when they first started adding the free 2 y maintenance -- and i even got a couple G off too!
    I felt silly getting the extended but a patient who works at another Toyota dealership noted that the standard Prius has 25 processors!
    I felt even sillier about the key replacement - but they quoted $400 for a replacement and the insurance was markedly less than that. (I've seen them on the net for aboaut 300, but still.)
  13. Judgeless
    1,821
    255
    Cleveland, OH
    Toyota and other companies have had many processors in the cars for many years. That does not make the car any more or less reliable. A better thing to look at is past performance of the company. Toyota, Lexas and Scion are the three most reliable cars in the world. After that it’s Subaru, Honda and Acura. The worst are Voltswagon, Jaguar and Land Rover.
    An extended warranty on the most reliable car in the world is not a wise investment. It might be if you are buying a Land Rover.
  14. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    If you have your car serviced, by anyone other than yourself, make sure you find out what viscosity grade of motor oil (0W20 for us) they are going to use. There have been some posts lately by people who have discovered some dealer's service departments used or wanted to use 5W30 or 10W30 non-synthetic oil in their Gen3 Prius.
    If you are going to buy a maintenance plan make sure it specifies the correct oil.
  15. lmgeee
    Whittier
    Hi everyone, thanks for your feedback. This is very helpful. Cost of prepaide maintenance plan is more than the $310 cost quoted above. Does this prepaid plan include both materials and labor. I get the impresion that some materials are not covered.
  16. DumbMike
    560
    119
    Los Angeles
    By the way, I had a tire company fix such a tire for free. The problem this time was that I drove on the tire for too long after it was flat so I caused more damage than just a plug would have fixed. That was my fault. So, I paid my money up front for my possible stupidity, I was stupid to drive on the flat tire (but I didn't know it was flat), and luckily, it didn't cost me any money.
    Mike
  17. DumbMike
    560
    119
    Los Angeles
    That's all true. Plus, I got a brand new tire. I'm not telling everybody to go out any pay for this insurance. I'm only telling you that it paid off for me. But I damaged the tire to where it couldn't be plugged, and I don't know what would have happened if that were known.
    Mike
  18. DumbMike
    560
    119
    Los Angeles
    The actually couldn't repair it as I damaged the tire. They did make their money. They didn't have to say what they did as I would have had to buy the new tire any way, and I already told them I was buying a new tire.
    Mike
  19. DumbMike
    560
    119
    Los Angeles
    Look at the list of things they will do. Note that most say "inspection." That does not include the price of labor or materials for the repair. If you want to do the inspections, great. Me, I'm too lazy. But that doesn't mean you should get the prepaid maintenance plan. You just have to weigh your options. I also believe it includes tire rotation (again, I'm too lazy to do that).
    Mike
  20. Southern Dad
    Southern Dad Active Member
    350
    212
    58
    Monroe, GA
    I wasn't going to get the maintenance plan but the last oil change on my 2008 cost me $70 for synthetic. I opted for it.
