Toyota prius 2007 hybrid ac refrigerator
Discussion in 'Gen 2 Prius Main Forum' started by Amin Omran, Jun 20, 2021.
  1. Amin Omran
    Amin Omran New Member
    Sweden
    Hej guys, my car ac give not cold air, I'm trying to find a good gas to put, any recommendations if this r134 is good for it, or if you have other products
    Thank you for helping
  2. Aegean
    Aegean Active Member
    428
    187
    Alexandria VA
    R134a is perfect but you need to evacuate what is remaining and refill it by correct weight in grams. Now if you like risks you can just add R134a slowly, wait a couple of minutes to check if vent temperature is getting lower and repeat a few times. Unfortunately, if you overcharge the system you can easily destroy your compressor in just a few weeks. The Prius AC system is very sensitive to refrigerant weight in the systemand not forgiving as the bigger and older R134a cars where you could add half a can more and still work fine.
