Toyota Prius 2007 parked for more than a year...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Alfred_M, May 15, 2020.
  1. Alfred_M
    Alfred_M Junior Member
    North Hollywood
    Hello everyone, I'm new here and I hope you guys can help me somehow.
    I'll try to be brief. Almost 18 months ago I had to leave the US to go back to my country, sure that I would have come back shortly. Unfortunately, things had changed and I couldn't fly back for a long time.
    I left everything inside my apt to some friends and my 2007 Prius is still parked in the same spot after all this time; huge mistake is that I kept the keys with me, so the car has never been used so far.
    Now the apt needs to be emptied and I don't know what to do with my car. I just shipped the keys so they are on their way.
    My question is: Before waiting for my friends to check, what kind of behavior should I expect from my car?
    Thanks in advance and I hope you're safe and sound during this awful time.
    Cheers!
    49,466
    welcome!
    first, you'll need a healthy 12 volt battery, likely a new one. then if it won't start, you'll need to have the trouble codes read. that involves flatbedding to a dealer. it is very possible some hybrid battery cells have gone out of whack after a year of not being used.
    all the best!(y)
  3. Alfred_M
    North Hollywood
    Thanks for your answer bisco! Do I have any small chance that the car will be drivable right away?
    Also, if all of this that you've suggested me is needed, should I better sell the car?
    Sorry for all the questions but this is MY very first car and I'm a bit worried for the outcome.
  4. JC91006
    16,482
    8,399
    2007 Prius will at least need a new 12v battery. But the HV battery (if original battery from 2007) "might" be salvageable if you can charge it BEFORE you attempt to start the car. This charge will balance out the HV battery.
    If you try to start the car without first charging the HV battery, it'll be almost 100% the car will need a new HV battery at that point.
    edthefox5 likes this.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Sounds like a wild guess to me.
    What evidence do you have that supports that theory ??
    I think that a new charged 12 V battery has a good chance to bring it back to life with no ill effects.
    Certainly worth a try.
    IF the car does run.....by whatever means.....what will you do with it next ??
  6. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Well, electrically, the car is going to be dead. Does the FOB have a working metal key to get into the car because the doors aren't going to unlock via SKS or the remote?
    Next, replace 12v. Period.
    Next, if the HV pack is original (or a marginal refurb), odds are it will either be dead with codes or very, very weak. If the latter and it somehow does indeed start the ICE (false starts by a weak HV battery sound like a running engine but it's really not running, this fools many folks including myself), do NOT attempt to drive it. Instead, immediately FORCE-CHARGE the pack till it hits green bars, then draw the battery down to purple bars by running the a/c full blast and headlights on high beam in Park and then another force-charge. If it doesn't code, then drive it for a long time so the pack cycles its SOC several times. If all this works, consider yourself one lucky Prius owner.
    GOOD LUCK!
    GrGramps likes this.
  7. JC91006
    16,482
    8,399
    hybridautomotive.com has write up about this. And of course, I actually fix these batteries
    edthefox5, fotomoto and Raytheeagle like this.
  8. bisco
    49,466
    it really depends on your financial condition, diy ability, and desires. personally, i would dump it. but that is not the case for many here who like to work on cars and enjoy the challenge.
    an old hybrid is a much bigger challenge than a straight gasser.
    i wouldn't drop 200 bucks on a new 12v until you've decided what you want to do if that doesn't fix it.
  9. Alfred_M
    North Hollywood
    Thanks everyone for your responses!
    The thing is that I don't know when I'll be able to fly back to the US so I was thinking that the best choice would be to tow the car to another friend's place. As every one of you basically wrote it, the car won't be drivable 100% unless I put at least a new 12v battery which will be around $200. If I go that way the car would be unused again for who knows how long more. So I was thinking to tow it or worst case scenario, to sell it. Also, I'm a newbie on this topic so I would appreciate if someone can explain me how to charge the HV, is it something I can do or should I bring the car to a shop?
    Thanks!
    * Also the keys can work both through remote and the standard way.
  10. sam spade 2
    7,035
    2,788
    2017 Prius c
    Ah yes, I see.
    When "Prolong battery systems" came up on the screen, I stopped reading.
    You don't really think that the information they post is NOT tainted by their commercial interests.......do you ??
  11. JC91006
    16,482
    8,399
    Believe what you want to believe. Some believe the Corona virus is fake news too
    edthefox5 and Raytheeagle like this.
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Prolong has worked fantastic for me. On my third year of maintenance.
    Its a hi volt battery charger. If you want to turn that into a conspiracy Trump would be awfully proud of you.
    Raytheeagle likes this.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    I used the Prolong equipment successfully for over 2 years before selling our 2010;).
    It was shared among 2 other owners that are members here and we rebuilt 2 batteries with it:).
    Definitely worked for the intended purpose and met the expectations I had for it(y).
  14. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Almost everything we buy, own or consume is backed at some point by commercial interests.
    That doesn't mean that item isn't a perfectly good product.
    What product would you go to a selling website and expect anything but positive description?
    Doesn't mean that description is invalid.
    I don't own, nor have I ever used Prolong equipment, but neither have I ever read a post by anyone that does own the system, that has been negative.
  15. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    There are some out there;).
    But when they call customer service, they get sorted:).
    It is an actual business and they have their own issues, but the equipment works(y).
  16. edthefox5
    10,096
    4,806
    Clearwater, Florida
    When I received there gear about 3 years ago the hybrid fan would not come on when doing a prolong charge. Its imperative the fan runs when charging or discharging with prolong as the battery will heat up!
    The fan supply circuit board that came with the Prolong package had a horrible solder job and wires were loose. That fan circuit board is used to run the hybrid fan at 100% speed during any prolong charge or discharge event. Very nice very smart. The battery would never ever see a 100% charge unless you use the outboard prolong system. And that really wakes a NIMH battery up but also creates alot of heat.
    Not a big deal I re-soldered it myself and its been fine ever since. I think they gave me some money back it was a long time ago but all in all there system has got me another 3 years out of my original 2007 battery and still going strong.
    So I am very glad I bought it. It works!
    Like any new cottage start up they had some manufacturing issue with my order or maybe its a one off for my issue. No big deal. They were responsive. And has worked fine ever since.
    So I recommend there product. I got the old school original system with the light bulb discharger. It worked!
  17. sam spade 2
    7,035
    2,788
    2017 Prius c
    It's not about "news" of any kind.
    It IS about the laws of physics and no amount of marketing claims can change that.
    2Fats likes this.
  18. sam spade 2
    7,035
    2,788
    2017 Prius c
    OK, I get it. Most of the proponents are in effect saying:
    Don't confuse me with facts, my mind is made up.
    And how many people spend hundreds of dollars on some "snake oil" and then admit that they were taken ??
    IF.....you start using it when the battery is fairly new, you have NO WAY to know if it did anything useful or not.
    IF.....you start using it when the battery is starting to show signs of failure, it might buy you a few days of extra use, which isn't worth the trouble.
    When the chemicals inside a battery are used up, it is DEAD.
    The DEAD don't come back to life.
  19. The Electric Me
    9,083
    5,798
    You have obviously never watched a George Romero film. The last 15 years in movies and TV, all the dead have done, is come back to shuffling, brain eating life.
    I've never owned the product, and I take it neither have you.
    So I can neither endorse or promote the product, nor condemn or denigrate the product.
    All I would say, is that for a majority of users that support the product, I think they believe the benefit is far more than just a "few days" of extra use.
    I think application is recommended not on the two ends of the extreme....New or Nearly Dead. Application is recommend in an aging but still viable battery. To balance and "Pro-Long" life. So your examples are IMO unfair. Yes, a dead battery, is a dead battery. But that's not the recommended application of the product.
    Again, I step aside from offering endorsement. I've never used the product. But neither am I going to conclude that the product belongs in the realm of "Snake Oil".
  20. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Getting over a year and half out of a battery that had failed is longer than a few days:whistle:.
    And this is one that we rebuilt out here with the Prolong Equipment;).
    If you catch the battery degradation prior to a failure, it saves having to find a module or two and swap them out, then recondition the entire pack:).
    Just a reminder of the ignore user function of Prius chat(y).
