Toyota Prius 2007's doors won't open: which battery is empty? 12v or hybrid?
Discussion in 'Gen 2 Prius Technical Discussion' started by Franck Dernoncourt, Feb 22, 2025.
Tags:
  1. Franck Dernoncourt
    Franck Dernoncourt New Member
    WA, USA
    If a Toyota Prius 2007's doors won't open when using the key fob's unlock button and assuming that the key fob is working fine, does it mean that the 12V-battery is empty, or that the hybrid battery is empty?
  2. spdracrm3
    spdracrm3 Member
    50
    43
    estacada or
    12v as the hybrid isn't even online till start is pushed. Should have a key on fob (release tiny latch to release) use that key to gain access go thru back seat to jump/charge 12v
    SM-G960U ?
    MAX2 likes this.
    51,011
    there's a safety release for the hatch door once you are in there, or you can put 12 volts on the jump point
  4. dolj
    dolj Senior Member
    8,182
    4,167
    Wellington, New Zealand
    It is easier all around if you unlatch the hood once you've gained entry to the car by way of the physical key and attach a 12V source to the jump point, as bisco says in his post above. This allows you to unlock the hatch, and then you can start with your diagnostics of the 12 V battery to find the problem.
