Toyota Prius 2009 start on, then died immediately
Discussion in 'Gen 2 Prius Technical Discussion' started by Maria98, Mar 17, 2020.
  1. Maria98
    Maria98 New Member
    Yemen
    My car Prius 2009 start on ready for just 3 or 4 seconds with (ABS, VSC, and break)
    then after few seconds (3 or 4 seconds), after that a red triangle with a sound has been appears on the dash screen,then the system immediately power off.
    I had tried that many times
    Could u please help me to solve this issue
  2. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Did you read the replies in your other thread? Prius 2009 it start ready for just 2 or 3 second | PriusChat
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    And I hope it was mentioned before attempts to make car ready will drain the hybrid battery then your in a whole nother world of hurt.
  4. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    What in it starts? If the engine seems to starts and then shuts down it's actually not starting and is draining the hybrid battery. Stop doing that as the hybrid battery will fail eventually!
    Put the Prius in ign-on by pressing the power button two times without pressing brake pedal. How many bars does hybrid battery have on mfd? Less than 2?
    Check the 12V battery voltage you can do that even without the volt meter: Toyota Prius: How to Check the 12v Auxiliary Battery Health - PriusDIY.com just do the Test 1. in step 5. then just power off. If that's bad you may need a new 12V battery or just charge it.
    If the 12V battery has enough voltage you will just need to read the fault codes. Codes are read in ign-on that you get by pressing the power button two times without pressing brake pedal. You will need a scan tool to read the codes best would be to use Techstream. Cheap way to get it is Mini-VCI. Then you could use it to read the codes and all freeze frame data. If you can post all that here we can surely help.
  5. bisco
    49,378
    folks, take a quick glance at o/p's history
