Toyota Prius 3rd Gen Transmission Filter
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by apt5020, May 20, 2016.
  1. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    I was at the dealer earlier today and ask them if they have the transmission filter. Weird is they don't have any information on the computer. Just only WS transmission oil. Everyone doing drain and refill?
    2007priuslol likes this.
  2. Mendel Leisk
    42,211
    There isn't a filter. Well, there may be one internal to the transmission, but there isn't one you can readily service.
    It doesn't really spell out in the attachment, but you basically add fluid, with the car level, till it starts coming back out. Both bolts are 29 ft/lb torque, require a 10 mm male hex socket. Stick with the stock Toyota ATF-WS fluid; if you purchase 4 qt's or liters you'll be fine: it should start coming back out around 3.5. You'll need a funnel with about 3' of hose*, to snake down through the engine bay. Do take the fill bolt off first, just in case you have problems. It's good to get fresh washers, especially considering it's an infrequent service.
    * Checked the OD on what I'm using, it's just under 15 mm. It fits with a little clearance, but pretty close to the limit.
    #2 Mendel Leisk, May 20, 2016
    Glojazzbent and bisco like this.
