Toyota Prius crash prompts emergency court filing
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Prianista, May 28, 2011.
  1. Prianista
    Prianista Member
    245
    Seattle
    From the Los Angeles Times:
    "Driver Gerry Young told KTLA-TV Channel 5 News that the car would not stop, even after she pulled the keys out of the ignition."
    I tend to use my key wirelessly, but I didn't know it was possible to pull the key out of the slot when the power is still on.
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  3. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    you can't pull the key out on Gen III.. oh wait you can't put it in either..
  4. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    But the car in question isn't a Gen III.
  5. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    I just don't get people if you push the power button at speed it still shuts the car down. Also if you slide the transmission to neutral it cant accelerate anymore? someone just looking for a payday.
  6. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    If you press and hold the button the engine will cut. if you put it in neutral the engine won't accelerate. Also, there is an override in the brake, I think, on these cars. This is obviously a person hitting the wrong pedal, I have no doubt about that at all.
  7. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    I think your wrong, i don't drive a gen II but on the III you need to hold the power button in for up to 5 seconds you don't just press it. Thats how the cop died in the lexus. And yes you can shift to neutral but again you to need to hold in their not just shift it and let go.
    I'm not defending the person that crashed just want to make sure people reading your post know the correct way.
  8. Duffer
    Duffer Member
    271
    How did she "lose control of her car"? She was behind the wheel and there for the driver of the vehicle. She pressed the gas pedal and drove the car into the building, using her car as a 3000lb weapon. Who regularly uses the key fob plugged into the dash like an old fashion key? It is wireless!
  9. bisco
    49,460
    pic kinda looks like gen III?
  10. adamace1
    1,403
    191
    Charlotte, NC
    not to me.
  11. bisco
    49,460
    not sure, but you're probably right.
  12. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Some people should not be issued a driver's license.
  13. austingreen
    austingreen Senior Member
    13,574
    4,114
    Austin, TX, USA
    She said that she left the car and it was still accelerating. This appears to be a gen II, is that correct? Do we know if a stuck pedal might have been at fault?
  14. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Yeah, it's a Gen II. Hard to tell from the pic for me, too, but in the video when they back it out (how could they risk operating such a dangerous piece of equipment!!!) you can tell more easily.
    If it was a stuck as a result of the floormat, it would seem that the responsibility is with the owner who never got the recall work done. I wonder if it's potentially something different from a legal perspective, but from a personal one...
    Also, while that's a remote possibility, the fact that so many vehicles happen to crash into buildings when parking seems to indicate that they were coasting through the lot and then went for the pedal - ideally the brake one - for the final stop, but were off by a bit too much. It would be too overwhelming to realize YOU'VE made a huge mistake by the time the engine is revving and the car shooting forward.
    Add that to her storyline conflicting heavily with reality (to paraphrase, the "my foot was off both pedals and it kept moving" story and also the "I took the key out of the ignition but it kept accelerating" story), and the vehicle-caused acceleration seems possible only in the farthest reaches of the imagination.
  15. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    These claims are so silly. Will someone please show this video on mainstream TV so people can come up with some other excuse for crashing Toyota's.
  16. austingreen
    13,574
    4,114
    Austin, TX, USA
    agree with most of this. I just am curious about what might have happened. I've heard gen 2 owners proudly say that the entrapment is made up and they aren't going for the recall. I wonder if this may have been what has happened, and it should not be difficult for investigators to figure out. With that speed wrong pedal is the most likely, but not the only possible explanation.
  17. stefano5777
    stefano5777 Member
    380
    47
    I just tried this and it took less than 2 seconds of pushing the power to turn of my Prius under power and putting car in neutral under power is no different than shifting gears normally. So I guess I'm not wrong.
  18. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    already a thread on this.
    another person who will readily blame anything and any body before willing to even consider the possibility that they made a mistake for no other reason to prevent themselves from being sued for damages.
  19. wwest40
    wwest40 Member
    518
    Pacific NW
    2003 Prius
    I
    First, let me state that I am of the quite firm belief that >99% of these SUA incidents are foot pedal confusion related.
    That being said there seems to be a slight indication that Toyota's cruise control firmware could be at fault. One of these "indications" seeming involved CC activating on its own, no driver action.
    Having been in the computer business since '67 I have the foundation to suspect the problem (0.001%) to be a dead-lock or live-lock in the CC firmware execution. Basically the engine/transaxle ECU is executing, EXCLUSIVELY, the CC "accel" mode. Paying NO attention, NONE, to the various switch or sensor inputs that would otherwise result in a shift into neutral, or even a complete engine shut-down.
    "..push the power button.."
    Disregarding the above possibility, just how many owners are actually aware of the need to not just "push" the button, but hold it down for 3-5 seconds in this circumstance.
    Ask 100 owners and I'd bet you the clear majority would not know.
  20. wwest40
    wwest40 Member
    518
    Pacific NW
    2003 Prius
    I
    But then your engine/transaxle ECU's controlling firmware wasn't in a "live-lock", executing ONLY the CC "accel" mode, was it..?
